Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 596.72913200 Refrigerator is Warm, but Freezer is Cold
I have a Kenmore refrigerator, model # 596.72913200. The top is the refrigerator and the bottom is the freezer.
Last night the refrigerator started warming up but the freezer is still cold.
The AC Evaporator Fan Motor seems to be running fine, I'm wondering if it might be the Defrost Timer.
Can you please provide step-by-step instructions to determine if its the AC Evaporator Fan Motor or the Defrost Timer.
How can I test these components to see if they are working properly.
What else should I check to determine the problem?
Thanks in Advance,
Lucy
  • 828 Answers
There should be a push in switch on the door frame that you can push to see if the evaporator fan is functioning. You will be able to hear it when you push in on the switch.
If your problem is defrost related you will see frost buildup on the back wall of the freezer . If it is defrost related it will be ether the timer, heater, or defrost thermostat that is your problem. If it is the timer, locate where the timer is. Sometimes located in the area of the temperature controls with a hole through which you can turn a clutch head screw clockwise very SLOWLY until you hear one audible click. This will start the defrost. if after 30 minutes it defrosts but does not start cooling again turn the screw just a little further and you will hear another click. The compressor should start. If this is you conditions the timer needs to be replaced. If it fails to defrost and restarts to cooling mode after 18-22 minutes the problem is in the defrost heater circuit.
Posted on Jun 03, 2008
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
My refer Kenmore coldspot) does not get cold. The freezer is warm as well. The fan and compressor kick on....... any best bet ideas
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
My kenmore top freezer is not cold enough. The temperature is not cold enough to make ice. how should I troubleshoot the problem?Model number is 106.8670680
heatman101
Aug 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have a kenmore cold spot 72102100. The freezer and refrigerator are not cold and if I touch the top of the refrigerator or if I open the freezer door and top the area where the door sits it is very hot....
heatman101
Jul 13, 2011 | Kenmore 65812
I have a fridge that was made in 1995 that the fridge stays warm freezer works fine I also can not fine a model @ that I can read
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
I have a kenmore refrigerator model # 596.61864101 with a freezer on the bottom that is not getting cold enough top and bottom . food in freezer is not frozen solid and food in fridge is not cold , just...
heatman101
Jul 01, 2011 | Kenmore Refrigerators
Kenmore model# 106 44563600 freezer gets cold refrige stays warm
There is a fan in the freezer that delivers cold air to the refrigerator compartment. Check to see if it is blocked or possibly not running at all.
If not working, a replacement can be purchased through www.sears.com under the parts direct tab. Just enter your model number and search out the part.
Aug 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
I have a Kenmore refrigerator (model 253.63732300) with freezer on top. The freezer section is cold but the lower section or the refrigerator section is not cold. It is warm. Any suggestion on why this is...
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Jun 14, 2009 | Kenmore 61042 Top Freezer Refrigerator
Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Sep 10, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
272 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
