Question about Xerox Phaser 8560MFP Laser Printer
Keeps showing 'add ink' after adding inks & turning off/on again
This method was for 8500/8550, but we have a 8560mfp and it worked for us (with some slight modifications...). Skip step #1 and do this instead to get to the Diagnostic Menu
Click the "System" button. Select "Information", then "Troubleshooting" then "Service Tools", and finally "Enter Diagnostic Mode".
"OK" below means the check mark button on our printer.
"This may include: Low ink error, add ink error or 09,035. Error codes and more.
1) Press and hold the red button (info button) and the "OK" button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the "Enter Diagnostics" menu. Select the "OK" button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select "ok" again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 "no test selected"
4) At this point hit the down arrow button until you reach the test #76. Select "OK"
5) It will ask for a confirmation. Select "OK" to confirm.
6) Then hit the down arrow button again and select the next test #75. Select "OK"
7) It will ask for a confirmation. Select "OK" to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. "Exit diagnostics."Select "OK".
9) It will ask for a confirmation. Select "OK" to confirm.
10) At this time the printer will again reboot for several minutes
Posted on Oct 15, 2010
Hp 6515 cartridge shows low after a refill
There is no such mechanism to detect ink levels in your printer., it wont detect if adding more ink in it., it will detect only new cartridge when you replace it., printer shows estimated ink levels as per the print outs. This is hp trick to aviod refill &non hp consumables...
Sep 30, 2014 | HP Photosmart 6515 Wireless Color All In...
I have just had my cartridges refilled and now have reinserted them in printer but it keeps saying remove and check colour cartridge (which i have done lots and lots of times), help please
Ink cartridge contains Ink tank, electrical circuit & print nozzles.
Adding ink to ink tank is called refilling, if any fault in circuit/nozzles will indicates the cartridge error.. Before refilling check cartridge health condition.
In your case its sure that cartridge faulty, go for new one..
Nov 10, 2012 | HP PSC 2355 All-In-One InkJet Printer
The ink carriage is stuck on the right side of the printer & won't move. There is nothing stuck in the printer to keep it from moving.
HI,
This is Neo , remove ink carriage and turn off the printer . Try to move it manually , do it softly . Turn on the printer and add the ink carriage .
Nov 01, 2010 | HP PSC 1410 All-In-One InkJet Printer
Hi my hp printer keeps say 3 on the screen and it says it out of ink but on the computer it shows us that we have enough please can you help thank you from Natasha.
Try unplugging the printer power from the wall for a good 90 seconds. Then replug it in. If it still shows needing new ink, try opening the cover to the printer, removing the current ink cartridge, then shutting the lid. Turn off the printer from the power cord again. Then plug it back in, turn it on, re-open the lid, and put back in the same ink cartridge. If it still has the problem and you are sure there is enough ink in the cartridge it sounds like the printer sensor has an issue.
Sep 09, 2010 | HP DeskJet F380 All-In-One Printer
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
I have refilled the ink cartridges on my Canon Pixma MP220 printer but how do i reset the printer to show the ink level is replaced as it is still showing low ink-thanks
try this
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again. dont forget to rate thank you
Nov 30, 2008 | Office Equipment & Supplies
HP C6150 printer....replaced ink cartridge & still show it needs to be replace.
Try to disconnect the printer, remove ink cartriges, turn printer off, wait a minute, then turn it back on, replace ink and connect to computer again.
Sep 16, 2008 | HP Office Equipment & Supplies
Xerox Phaser 8560MFP Laser Printer Logo
349 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
