Question about Gaggia Titanium Espresso Machine
My Titanium keeps saying "fill watertank" I have filled the tank, switched the machine off hoping it would reset but same message!!
    Scholar:
  • 29 Answers
See if the small black float is able to move up and down in the water tank. You have to clean the water tank every so often, it will get slimey in the tank and it's possible some build up is preventing the float from moving up and down.
The float is dark in color and about 1 inch by 3 inches by 1/4 inch rectangular shape. It is magnetic and works a magnetic switch that is inside the machine.
Posted on Oct 14, 2010
Can't get system fill message off jura impress z5
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
Oct 05, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
Screen says 'Fill Watertank' when watertank is clearly full.
Sounds like the sensor that detects system water levels has failed.
If you can see it inside try cleaning it or ask Miele for some advice via their website
Apr 14, 2010 | Miele CVA615 Espresso Machine
Have just descaled the machine. filled the reservoir with water but machine is telling me fill watertank.
When putting the tank on the unit make sure you tank makes contact with the back of the machine all the way down so that the reed switch reads the tank.
Jan 11, 2010 | Gaggia Titanium Espresso Machine
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Miele coffee system "Fill Watertank" issue
there is a liltle floating black thing at the back of the container, this works as a magnet switch. see if it is there or is stuck and doesnt raise with the water level.
Apr 13, 2009 | Miele Coffee System
Fill watertank message will not go away
This happened on my unit. There is a magnetic float in the tank that rises when the tank is filled. On my unit, the float (which is supposed to be sealed) took on some water, and stopped being bouyant. I had to break off the clear plastic cap that keeps the float in place, remove the float, and ***** a tiny hole in the float and squeeze out the water. Now (since I have a hole) I have to do this repeatedly - every week or so - though its easy to remove the cap now. Still looking for a replacement part.
Dec 30, 2008 | Gaggia Titanium Espresso Machine
Frosen
The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water i wanted you to use to rinse, now you're finished." It takes a LONG time if you fill the tank. If you keep filling the tank, it will just KEEP going. Be patient, let the tank run out of water and this will trigger the end of teh cycle. Hope this helps, Tony.
Sep 11, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
485 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
