Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
The refrigerator won't turn on when I plug it in. Any idea what the problem could be?
  • 49 Answers
Defrost timer could be in defrost cycle and stuck. You may have to replace it. if you have no light, no compressor noise and no fan running inside, it is a defrost timer, bad plug or no power.
Posted on Oct 13, 2010
Won't cycle
That would be the thermostat. Can order online.
May 12, 2013 | Haier Refrigerators
Tip
How to fix a Refrigerator that Doesn?t Cool or Runs Constantly
If the refrigerator’s light works and you can hear the refrigerator running but it cools poorly or does not stop running, make sure nothing is blocking the passageway between the freezer and the refrigerator compartments. If airflow is restricted by, for example, a loaf of bread situated in front of the passageway, the refrigerator won’t get cold. Be aware that a refrigerator will tend to run longer when it’s full of food, the door is opened frequently, or the room temperature is hot.If your refrigerator runs without stopping, it may be low on refrigerant and cannot reach the low temperature that the cold control dial summons. More likely, it is a defrost problem in which a component in the automatic defrosting system is faulty. This could be a defrost heater, a defrost timer, or a defrost terminator.
Before you call a repairperson, do the following:
1) Determine whether the refrigerator section is being cooled. If you see frost at the top of a “frost-free” refrigerator even when the cold control is set low, it means the refrigerator probably has a full charge of refrigerant and it is the thermostat that is faulty or out of calibration.
2) Try turning the cold control both up and down. If the compressor doesn’t shut off, the cold control may be broken. Call a repairperson. During the repair, it is a good idea to have the defrost timer and heaters checked to ensure they are working correctly.
3) Look at the condenser coils, located at the bottom of the refrigerator (behind the kick plate) or, in some cases, at the back. These coils disperse heat from inside the refrigerator out into the room with the aid of a fan. If the coils are dirty, the refrigerator won’t operate efficiently. You must clean them regularly.
4) Make sure the drain line under the evaporator coils, which goes to a pan underneath, is not plugged up (water should drip into the pan when the refrigerator is defrosting).
5) To put off having the refrigerator repaired for a few days, you may be able to defrost it manually with a hair dryer—if you can access the cooling coils in the freezer section. Excessive moisture in the coils can turn into a frozen mass, reducing efficiency. Be very careful when using the hair dryer near a water source as there is a serious risk of electrical shock. Also be careful not to melt the plastic parts.
on Sep 02, 2010 | Refrigerators
Mini refrigerator won't come on, no power when plugged in.
Did you check the fuse? Do you have power at the unit?
Mar 26, 2013 | Refrigerators
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
My 1991 Kawasaki JS440 jet ski won't start and it
You might want to post this question in a different section. This is the computer games section.
Aug 23, 2012 | Video Game Consoles & Games
1980 Suzuki Gs450L won't start. I stalled out pretty bad in 4th gear and it won't start back up after. Bike won't even crank over, just makes a clicking noise. Any ideas?
pull the plugs then crank motor you may find one cylinder full of gas and that will keep it from cranking, if it cranks without the plugs allow it to dry for a bit , make sure plugs are dry then install and hopefully GO!
Jul 04, 2012 | Suzuki Motorcycles
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
We can't get our Dometic fridge to light when it's turned to gas. Model number 2453. It works on AC and DC but just won't light at all on gas. The gas will light but won't stay lit in the...
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Jun 27, 2011 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
