Question about AO Smith Air Tools & Compressors
NEED A REPAIR MANUAL OR TECHNICAL MANUAL FOR A SMITH COMPRESSOR MODEL 185CFM S/N 185 21875 2300 ROM
3 Suggested Answers
  • 54 Answers
SOURCE: I need a service manual for Ingersoll Rand 185cfm
I don't believe you can view these online anywhere. These comprerssors are now owned ny Doosan. You can order a service manual from your Doosan dealer. You will need the product code that located inside the side door of the compressor. Usually near the oil cooler.
Posted on Nov 28, 2009
compman66
  • 169 Answers
SOURCE: 1989 Ingersoll Rand 185 diesel compressor shuts down under load
most have safety shut downs built in, on the compressor side you will have a high discharge temp shut down, usually set to shut down @ 230 degrees F. normal temp should be @ 180F if it is running hot first check oil level on the compressor, and that the radiator is clean. some machines will have a thermostat that will only allow oil flow to go to the radiator after it comes up to about 150 degrees F. you really need to have a manual on the machine to see what other safety's it may have on the compressor and engine side as well.
Posted on Jan 09, 2010
Testimonial: "Thank you very much for responding. It was a little low on coolant. The comp. oil level was fine. I changed the fuel filter and the prob is gone"
Smith Corona-Model5 5P uses H ribbon. Spellright-correcting. Dictionary. Needa manual and ribbons.If you can help call 423-344-3516.
Smith Corona 5p Series Electronic Typewriter Parts ' Model ...
www.searspartsdirect.com/partsdirect/part.../Smith-corona.../0544000
Shop for Smith corona Smith Corona 5p Series Electronic Typewriter repair parts for model 335DLE(5ADF) at Sears PartsDirect. Find parts, manuals & diagrams ...
Mar 05, 2015 | Smith Office Equipment & Supplies
I need a manual for a Smith Corona Model NA3HH
Google Will Repair in dunkirk NY they may be able to help.
DickyO
Mar 23, 2012 | Smith Corona Office Equipment & Supplies
I purchased a 60 gallon compressor from Lowes which has a 230 volt single phase motor,3450 rpm,15 amp. The model # of the motor is 7-194160. There is no wiring diagrm in the manual. I was wondering where I...
There may be a wiring diagram either on the body of the motor or inside the wiring terminal cover.
A.O. Smith can be contacted at 800-262-6484. If you do call, have pertinent motor info ready.
Nov 30, 2010 | AO Smith Air Tools & Compressors
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
There is not a point setting for air compressors. The pressure switch can be adjusted. Remove the cover from the pressure switch. Adjust the nut tighter for a higher cut off pressure or looser for a lower cut off pressure. It sounds like the compressor is trying tostart under load. If the unloader valve is not working, the compressor will draw excess amperage and do what you describe. The unloader valve releases the pressure in the cylinder at the end of the run cycle so the compressor can start the next run cycle under no load.
May 14, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Jan 08, 2010 | Air Tools & Compressors
My 1998 atlas copco xas 97 185cfm deutch diesel shuts down when i open full air
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
Nov 04, 2009 | Air Tools & Compressors
I need a service manual for Ingersoll Rand 185cfm air compressor
Oct 31, 2009 | Air Tools & Compressors
Need owners manual: Smith Corona SL500 Model 5A, electric typewriter. Where can one find this? Are there any that can be down loaded? Does Smith Corona even exist anymore? Thanks, kms_soykey@msn.com
I have been unable to find a site where you can download a Smith Corona typewriter manual. However, you can try going to Will Repair Service. They carry manuals of every Smith Corona typewriter ever made, and you should be able to find a manual for your particular typewriter there. I find them to be a very helpful and trustworthy typewriter shop.
YES, SMITH CORONA DOES STILL EXIST!
Best of luck to you! :-)
Apr 25, 2009 | Office Equipment & Supplies
Air Tools & Compressors Logo
73 people viewed this question
Top AO Smith Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an AO Smith Air Tool and Compressor Expert? Answer questions, earn points and help others
