Question about Milwaukee Tool Milwaukee 6215 Electric Chain Saw
WHERE CAN I BUY BAR ADJUSTING WRENCH SCREWDRIVE
WHERE CAN I BUY BAR ADJUSTING WRENCH SCREWDRIVE BAR ADJUST WRENCH. 16inch SPROCT NOSE BAR. SCABARD. ALL FOR MILAUKEE 16 INCH ELECTRIC CHAINSAW MODEL 6215 THANK YOU JIM
  • 7,733 Answers
Try here ->link.
Posted on Oct 14, 2010
Adjusting an electric chainsaw bar and chain
UN PLUG FIRST THEN Loosen the bar and lift with the chain then tighten with a screwdriver the screw is normally found at the front beside the bar re tighten the bar the chain should not be over tight check chain oil
Jul 17, 2014 | Poulan 16Inch 30 HP Electric Chain Saw...
Tranny clunks when put in gear on my 1998 sporster 1200
Getting this, to not be so jerky, may be as easy as adjusting the clutch. open up the derby cover and ..
1)Collapse the adjuster on the cable sleeve all the way.
2)Pull the lever against the bar and hold it there with slight force.
3)Turn the pushrod adjuster bolt in while holding the lever against the bar lightly until it starts to force the lever away for some distance. (Do this more than once to get the feel). While keeping light pressure on the lever back the adjuster bolt out just until the lever touches the bar again and then another little bit, about 1/2 turn , then lock it.
4)Adjust the cable freeplay at the lever for 1/16" free play.
You should be good to go .
Always adjust the clutch on a cold bike for best results.
**It's better to adjust the clutch so that it starts to grab at least an inch or more from the bar for complete disc separation, which translates into better/quieter shifting.Using this method, you can "feel" where the lever is going to grab with a little practice.
Buy yourself a cheap 11/16 deep well socket and weld a nut on top of it. This makes the perfect tool for the adjuster lock nut. You can then use an Allen wrench inside the socket and a wrench on the nut you have just welded on. Makes it a lot simpler.
You can also see "clutch adjustment by the book" in this same forum found-- HERE.. Hope this helps Fix Ya up..
Jun 19, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Where can I buy a wrench to adjust the carberator
Normally you would need a screwdriver.But the adjustment screws on your saw have plastic caps on them that will only turn about a1/8 of a turn.these are pre-set at the factory.you will need too take carb off and clean it out.if that doe,s not help it needs to be rebuilt or replaced.
Dec 03, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I cannot find my manual to my 18v cordless chainsaw ccs818. I need directions for putting the chain back on. I would like to download a copy of the manual.
Your manual can be found here:
http://www.blackanddecker.com/Manuals.aspx with pop-ups enabled then enter your model number
or
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
See the instructions for replacing the chain on page 11. It makes reference to the figures on page 6 so that you know exactly what to remove.
Basically... loosen the bar allen screws. Remove the sprocket cover. Loosen the bar retaining bolts. Use a flat bladed screwdriver on the bar / chain tension screw to shorten the bar enough to install the chain. Then adjust the chain tensioner so that there is just a little slack in the chain at the bottom of bar between the drive sprocket and the bar. Tighten the bar retaining bolts install the cover / tighten all cover fasteners. (see details D and E page 6 of the 2nd link above.)
The steps below are copied from the manual.... I can not undo the formatting and can not post the figures here due to size restrictions..
Thanks for choosing FixYa,
Kelly
Replacing the Saw Chain
CAUTION: Sharp chain. Always wear protective gloves when
handling the chain. The chain is sharp and can cut you when it is
not running.
WARNING: Sharp moving chain. To prevent accidental
operation, insure that battery is disconnected from the tool
before performing the following operations. Failure to do this
could result in serious personal injury.
• Place the saw on a firm surface. Rotate the two allen head screws
(11) counterclockwise with the wrench (13) provided as shown in
figure E.
• To remove the saw chain (9), rotate the tension adjustment screw
(23) in the front of the housing using the flat screwdriver end of the
wrench (13) as shown in figure F. Turning the screw
counterclockwise allows the guide bar to recede and reduces the
tension on the chain so that it may be removed.
• Remove sprocket cover (10) and allen head screws (11).
• Lift the worn saw chain (9) out of the groove in the guide bar (8).
• Place new chain in groove of guide bar making sure saw teeth are
facing correct direction by matching arrow on chain with graphic on
housing shown in figure G.
• Place the saw chain and guide bar assembly around the sprocket
(19). Check to make sure that the slot (20) in the guide bar (8) is
over the two location pins (21) shown in figure E and that the hole
below the slot is located over the adjustment pin (22).
• Replace sprocket cover (10) and thread allen head screws (11) in
with wrench until snug, then back wrench off one full turn.
• Pull bar nose up and keep it up as you adjust tension.
• Rotate the tension adjustment screw (23) in the front of the housing
clockwise to increase the chain tension as in Figure F.
Follow instructions in "Adjusting Chain Tension" section.
• While still holding the bar nose up, securely tighten the rear allen
screw (11) first, then tighten the front allen screw.
• When the chain is new check the tension frequently (after
disconnecting battery) during the first 2 hours of use as a new chain
stretches slightly.
not running.
• With the saw still on a firm surface check the chain tension. The
tension is correct when the chain snaps back after being pulled
1/8 inch (3mm) away from the guide bar (8) with light force from the
middle finger and thumb as shown in figure H. There should be no
"sag" between the guide bar and the chain on the underside as
shown in figure I.
• To adjust saw chain tension, loosen the allen head screws (11).
using the flat screwdriver end of the wrench (13) as shown in
figure F.
• Do not over-tension the chain as this will lead to excessive wear
and will reduce the life of the bar and chain. Overtensioning also
reduces the amount of cuts you will get per battery charge.
• Once chain tension is correct, tighten allen head screws (11).
stretches slightly.
Nov 08, 2010 | Black & Decker Garden
Chain tightens
For your safety DO NOT leave part of the drive link exposed no matter what some so called expert recommends.
Normally if the nose is not held up when adjusting a chain it slackens. Are you sure the oiler is working? Hold the nose 3 - 8" above a surface (newspaper works well) rev it up a little. You should see a line of slung off oil slowly appear. If excessively tight to begin with, friction may be causing this.
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
Dale this is a safety item. I suggest you take your saw and cup of premium black coffee to one of your local chainsaw outlets. A sales person should be willing to demonstrate (gratis but no promise) proper tensioning. Buy a couple of replacement chains or some 2-cycle oil while there as a thank you. Please reply below with what you find. Good Luck. HTH
Lou
Feb 26, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have an 18 inch bar and the chain has to be tightened every few minutes. I tighten the nuts against the bar as tight as I can but the bar must still be moving to loosing the chain. Do I need to add lock...
There is an adjusting pawl with a screw that does the tightening. The nuts only clamp the bar once the chain is tightened. The adjusting screw is in the plane of the bar. The pawl may have disengaged the bar or may have broken.
Jan 01, 2010 | Poulan PP4218AV 18" Chain Saw
How do you adjust the chain tension on a husqvarna 350 chainsaw ?
I don't own a 360, but most saws you have to loosen the two nuts that hold the bar on, and adjust the adjusting screw that points toward the front of the saw while holding up on the tip of the bar. Tighten until the chain is snug, but still loose enough to be able to spin the chain on the bar.
Dec 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain keeps coming off and when is on wont cut
If you are having difficulty fitting the drive links into the bar groove, the chain binds or rides up when rotated there may be burrs on the drive links. These often form if the chain comes off while at speed. use a file on the drive link flats to remove them.
Chain Adjustment
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Nov 25, 2009 | Garden
How do i tighten the chain on a stihl 038av magnum?
Normally, a loose chain will enhance it's ability to jump off when trimming small branches.
When installing and/or adjusting a chain;
1) install the chain, bar, and cover, and install the cover nut loosely
2) support the 'nose' end of the bar with a block
3) tighten the chain until it touches the bottom of the bar,
and then tighen the adjuster 1/8 of a turn more.
*this will make the chain just a LITTLE snug
4) tighten the cover nut, and then by hand CAREFULLY rotate the chain.
If you cannot rotate by hand, it is too tight. re-adjsut
** This proceedure must be used on ANY brand chain saw.
Here is why.
If the bar nose is not lifted upon adjustment, when cutting,
the nose will move upward, the chain will have a 'droop' away
from the bar and appear to have loosened while cutting.
Any contact with a small branch will flip the chain off of the bar.
If you re-adjust it improperly, the same senerio will occur the next cut.
Nov 22, 2009 | Garden
Here is why.
Nov 12, 2009 | Remington Electric Chain Saw
Milwaukee Tool Milwaukee 6215 Electric Chain Saw Logo
29 people viewed this question
Top Milwaukee Tool Garden Experts
Dennis Key
Dennis Key
john h
Are you a Milwaukee Tool Garden Expert? Answer questions, earn points and help others
