SOURCE: GE 35GT690 (No remote, how do I set it to Video?)
probably you could try this push down the channel up and down button together.you menu will pop up then you can change your setting with the volume up and down button good luck.any further assistance contact me at email [email protected] or on the fixya.com expert website.
SOURCE: GE Universal (JASRM24912) Remote Control
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: need to reset v chip on ge tv 19gt243
Reset the password to '0000' by holding the VolumeDown and ChannelUp buttons on the TV (not remote) for about 5 seconds. Do this while viewing blocked content- you'll see the screen blink when it gets reset. Then go into the menu and disable/change the v-chip settings as desired using password '0000'. Hope this helps- -sv-
SOURCE: RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
