Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
My ice maker is dripping water toward only the front causing the ice to freeze underneath. Is there anything I can do to fix this?
  • 49 Answers
You may try leveling the refrigerator.
Posted on Oct 13, 2010
What would cause my ice maker to leak into the plastic ice bucket?
The most likely cause is the fill valve is leaking and causing the ice maker to overfill. Try a new fill valve. Usually located on the rear of the appliance. (where you hook the water line to).
May 02, 2014 | Whirlpool GZ25FSRXYY
The ice maker is freezing up as is the ice in the bin. The water is freezing in the channel before it fills the "tray"
Easy peasey fix. Get a new water valve. Yours is dripping like a faucet.
Causes ice to stick together and the fill tube to freeze.
Apr 27, 2011 | Refrigerators
Water is dripping into ice recepticle and causing ice to freeze together. seems to be dripping near the front. the model number on my amana is DRS 246 2B or(RB) orDRS266312 those are the numbers on the...
sounds like u have a bad ice maker or a bad water solenoid in the back of fridge just not shutting off all the way and letting water continiously drip into ice trap
Feb 24, 2010 | Amana ASD2622HR Side by Side Refrigerator
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE freezer (side by side) if forming ice at bottom of freezer. The problem is unrelated to the ice maker and water feed (have them turned off), and appears related to the heating element causing water to...
There is a drain that should be visible just beneath the heater, it may be embedded in formed ice block. The drain is likely clogged and can be cleared by using a turkey baster with hot water to force water through it unto the pan underneath.
Jun 06, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Water drips from underneath icemaker and freezes in bucket
If you find the offending part of the ice maker, I've had good luck with these guys when ordering spare parts. Here is a link for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133512
Jan 01, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker freezes Whirlpool gold
try to remove all the ice in the bucket first and start all over again. the first bundle of ice could be the one making the problem. and then check the cold air vent towards the ice bucket. there should be cold air blowing to it to maintain the temperature in order for the ice not to melt.
after removing all the ice and inspecting if there is cool air coming out towards the ice bucket. let it run and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
