Question about Poulan Pro Chain Saw 46cc 20"
My oiler doesn't seem to pump oil. It doesn't seem to be cloged either. I suspect that it is the oil pump. How to change.
  • 7,733 Answers
Try both the diagrams and the part you need at eRP.
Posted on Oct 13, 2010
Chain oiler not working
wow this seems to be a more frequent complaint with folks bringing me there saws to look at lately , what I almost always find wrong is debris in the oil tank hence it's in the oil pump too , this requires a total take apart and clean it out service , also folks seem to not know what oil goes in there and add just any kind they have (even 2cyc oil) me I like to say u use Bar chain oil , this most times is 30w or less if it gets any heavier or lighter the oil pump M/T's the oil tank out first before the fuel tank goes M/T , oiler is not adjusted correct if your not needing to add oil with every gas tank fill
Aug 31, 2015 | Ryobi Garden
Mcculloch Mini Mac 30 Oiler does not work. cant figure out if it is the Oiler or the manual pump to feed the oiler
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Dec 11, 2012 | McCulloch 1975 Mini Mac 30 Chain Saw Sales...
My homelite chain saw is not getting oil on the chain from the automatic oiler?
either a faulity oiler or oil lines cloged try using compresed air to clear the lines by blowing in the oil tank
Nov 15, 2011 | Garden
Chain oiler does not seem to be putting out enough oil,what can i do to increase the flow?
This model does not have an adjustable oiler. If the ports are clean and the pickup is clean, you may need to replace the pump. This is generally an inexpensive repair.
Feb 20, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
My Poulan Pro PP4620AVHD bar oiler is not working at all. I have cleaned out the oil holes on the bar, but still no oil on bar. Is the pump located inside the oiler tank?
The pump should be located just behind the clutch assembly which needs to be removed to access the pump. Have you run the engine with the bar and chain removed? The oil should ooze out of the engine side port where the bar fits up to. If not, then the pump is certainly suspect. There is a filter in the oil tank which might be plugged. The clutch has left-hand threads and can be difficult to remove. Don't try to use an impact wrench with adapter as it will cause the flywheel key to shear. Hope this helps!
Oct 23, 2010 | Garden
Oil it must be from the bar oil compartment is getting into the cylinder. The saw will start but lots of smoke. The bar doesn't seem to be getting enough oil. This is a PM 610
Good Luck Donald;
Your saw model is 600041; there are many prefixes and suffixes applicable to your saw, I defer to you determine the correct one. It has an impulse driven oil pump (all are similar). I suspect a portion of the oil pump has failed and engine vacuum is pulling oil into the crank case. You can find an IPL for your saw that will be may be helpful with oiler components and disassembly/reassembly. Your oil system appears to be quite complex.
Your IPL is here:
The IPL (exploded parts list) for your saw is the only detail for the oil system but it is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 20, 2010 | McCulloch Garden
Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX: Oiler doesn't seemed to work...
a common problem. Only way to fix is take it to a repair shop to have the oil pump replaced.
Apr 28, 2010 | Garden
The chain oiler quit working or is cloged and in not sure how to clean it or take it apart
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
If no oil after 1 probably an oil pump. Post the make, model, and serial numbers below the advertisements and we can provide some more guidance.
Nov 19, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The auto oiler for the chain is not working, what should i look for
Hi
try this steps and proceed from one to the next :
1. make sure you filled oil
2. clean the chain oil container with gasoline
3. try thinner oil
Jul 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro Chain Saw 46cc 20" Logo
140 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
