Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Freezer not freezing chilling only has it packed up pls tell me
  • Candy Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
Won't Chill or freeze. The thermostate was replaced.
Did you change the thermostat or the thermistor? Thermistor is probably your problem.
Jul 24, 2015 | GE Profile PSW26P Stainless Steel Side by...
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
My food although in freezer bags and even store wrapped(sealed) will still end up with frost on it how can I stop this from happening?It is a ROPER
its only moisture inside the wrappings freezing,it will stop freezer burn,you could chill it before you freeze it but that means you would have to rewrap every piece of food again with a vacuum sealer.to make the packets airtight.(when we freeze homegrown veg we always vacuum pack it into portions,so it keeps better).
Dec 07, 2010 | Refrigerators
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Freezer wont freeze beyond a chill. Please Help
Sorry to say that this happens a lot. More then likely there is a refrigerant leak and the place you bought it from had it charged right before you saw it. That is why it worked then, but not when you reached your destination.
Jul 09, 2010 | Freezers
The lights are not on in either the refrig or the freezer. I can't tell yet if it's completely not working or if it is still chilling everything. What do I do?
cheapest way is to buy a freezer thermometer.try putting tray if water in freezer, if it freezes its working.........
Feb 09, 2010 | Refrigerators
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
First use - it didn't freeze
Try lowering the temperature of your freezer a few degrees. I had the same problem and this solved it.
May 10, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
57 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Billy Detlefsen
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
