Question about GE PSS26LGS Side by Side Refrigerator
My freezer stays defrosted too long and melts all the ice, then refreezes causing icecycles
  • GE Master
  • 43,501 Answers
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
Water pooling and freezing on bottom of freezer compartment. Where is it coming from??
If you have an ice maker in there it could be that there is too much water entering the tray and the excess spills out. OR the drain that gets rid of melted ice during the auto defrost cycle could be clogged and the water stays in freezer, pools and refreezes.
Oct 08, 2015 | Refrigerators
I have a Kenmore top freezer. Every few days the freezer will get warm enough to cause the ice in the ice maker bucket to melt a little and then it will refreeze into a big block of ice when the...
Hi, It is sticking in the defrost mode...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
The defrost cycle seems to stay on too long-ice already made will start melting & then refreeze into 1 big chunk. Eventually the "melt" will build up in the bottom of the freezer & will eventually...
if think your defrost cycle is ok . there is a defrost terminator that controls the heater at 50 deg in the back of freezer , the problem is the water delivery tube is iceing oven and causing water to run down the back of freezer wall . change the tube to newer style. it will be open on the top side . they work better. and the water valve may be leaking through. and may have to be changed .. ,,
Jul 29, 2010 | Refrigerators
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
The ice in my ice maker bucket is melting and refreezing into a solid mass. I just looked at a recently made cube and it still has liquid in the center.
Yours has a 215846602 Defrost Timer, Located inside the fresh food compartment. I believe that it's sticking in defrost and you possibly need a new defrost timer.
Here is a photo location of the timer # 23 is the timer. I want you to turn the timer until the refrigerator compressor stops. Time it for about 25 minutes and the refrigerator should restart. If not then it's sticking in defrost so again turn clockwise slowly until the compressor restarts. That is possibly what is causing the melting and refreezing. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 19, 2009 | Frigidaire FRT18S6AQ Top Freezer...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
WATER IN BOTTOM OF FREEZER/TURNS TO ICE FRS28XGCB
its probably the automatic defrost cycle.there should be a drain in the bottom of your freezer,and it must be clogged.The automatic defrost keeps ice from building up in your freezer by melting it,and letting the water run out the drain.If the drain is blocked by something or clogged the water collects,and refreezes.You need to unblock the drain.
Mar 20, 2009 | Frigidaire Refrigerator Light Switch -...
GE PSS26LGS Side by Side Refrigerator Logo
157 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
