Question about Euro-Pro Steam Generator EP8001 Iron
I have a russell hobbs iron 14196 the digital revolution and when i press for the steam nothing comes out
snakehead
  • 1074 Answers
SOURCE: Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
snakehead
  • 1074 Answers
SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Jul 27, 2009 | Irons
Euro-Pro Steam Generator EP8001 Iron Logo
125 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
