Question about Logitech 980374-0403 Consumer Headset
USB Headset mM/N:A-0374A mic problem
My headset worked fine for a while and now i can hear sound from the headphones but the mic doesn't work. i have checked all my sound settings and they are set right. pluss the mic doesn't pass the hardware testing in sound options.
  • 6 more comments
  • nicholas_B Jun 18, 2008
    same here, Even weirder, is that if I test my mic, and I have a friend talk through it, It picks up him talking, as if i am speaking through my mic...
  • Anonymous Jul 15, 2008
    Same Problem here, Sound works great, plug n play and all that, but Mic just stopped working. Wont pass sound test either.
  • welzybob Jul 20, 2008
    Same problem no sound from mic but perfect sound from headphones need help
  • thedream613 Oct 11, 2008
    I have the same problem my mic was working for awhile then it just stopped everything is set correctly and my sound works perfectly
  • degross Oct 23, 2008
    The mic works for awhile and then stops working.....after awhile it then starts working again....maybe a loose wire? Can I get it replaced by Logitec?
  • Anonymous Feb 14, 2009
    same here. im so pissed.
  • paniolo39 Apr 01, 2009
    same problem here.
  • Anonymous Mar 15, 2014
    It does not read my mic and I can't figure out why; the mic works fine for skype, I checked my browser's settings and it is allowing tinychat to use it, and nothing I know of is working.
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
Posted on Dec 29, 2009
Why does my headphone audio get heard through my microphone?
Hi Matthew
I trust you are well.
Have you tried to plug your headset into the rear ports of your PC and not the front. If you have speakers in the rear and headset in the front try to swop the two around and see what happens.
Hope this helps
Kind regards
Aug 15, 2014 | Steel Series SteelSeries 7H Headset -...
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
Jun 23, 2013 | Turtle Beach Ear Force X42 Headset
I got new Logitech Clearchat stereo headphones. I plugged the two pins into the pc - pink and green. When I do a skype test I hear the message from my computer speakers (settings says Realtek HD..with no...
realtech hd is your sound device. go into windows control panel and access the sound settings then navigate to voice settings click the volume button,your mic might be muted. also if you want the headphones to work plug them into the plug that your speakers are using (side-note: mics and head phones never need something installed to work as long as your sound device works and your definitely does work,only when the mic is a special interface like USB do you need to install software and/or drivers)
Apr 01, 2011 | Logitech ClearChat Stereo Headset Headset
How can i attach a bluetooth to ps3 plz help
Hello my friend this should help you out.
please remember to leave a positive rating for me and a testimonial if I helped you out!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
and here's a video in case you are a visual learner.
Mar 26, 2010 | Sony Video Game Consoles & Games
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
When i talk people cant hear me though turtle
If you have an X1 headset...
Try using the X1 headset and mic with your PC (sound card). Green plug goes to green jack, Pink plug goes to pink jack. Can you hear your voice thru the X1 mic on your PC? If yes, then the mic works but the chat-controller cable is probably broken and should be replaced. If no, then the mic may be broken and you should contact Turtle Beach's tech support for help -- support@turtlebeach.com.
Mar 04, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Microphone suddenly stopped working
Try uninstalling and reinstalling your sound card driver. Also do the same for any software that has anything to do with your sound card. If this diesn't work, try restoring to a point before you had the problem. If you is usb and one is standard then it has to be soundcard or software, more then likely it's a driver issue.
Aug 12, 2009 | Computers & Internet
Mic is not recognized
i have a GE 98980 headset and window vista wont reconize the mic but the headphones work fine. How do i get the mic to work?
Jun 02, 2009 | GE (98980) Headset
Logitech usb headset A-0374A does not play
probably need to set the Logitech headset as your default device in Control Panel-Sound. XP or Vista updates may reset the audio-video default devices
Nov 19, 2008 | Audio Players & Recorders
Logitech 980374-0403 Consumer Headset Logo
3,607 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
