Question about Sony KDS-R60XBR1 60" Projection HDTV
Large fan stopped working. Removed and cleaned checked the connection several times and reinstalled. Fan started working and then stopped. Repeated process with same results.
  • Willie Howell Oct 13, 2010
    does the lamp come on?
    does any lights come on in front? do they blink? how many times? does the lamp come on and then go off. do you have any sounds like whining motor when you try to turn it on
  • 4,348 Answers
Replace the fan or suffer overheat.
Posted on Oct 13, 2010
Ge zv850 vent hood
was this a d.i.y. project, if so was a proper ground ran from breaker usually a size bigger than the power. when the fan goes out does the light do the same, as u may have crossed your device wires. electrical can be tricky because there can be several reasons for your issue. u suggest u double check your work ensuring everything is
Feb 17, 2014 | Kitchen Ranges
Computer gets hot and stops
Please check if its fan is clean and working (there is a fan just over processor) otherwise, this will be repeated with increasing frequency.
Oct 02, 2012 | Apple 24" iMac Desktop
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 | Ovens
Bought a used 93 mazda protege.(as is) A/C compressor does not start or engage.. When warmed up and running large primary fan is on. I fouund aux fan fuse removed from fuse box.under hood. I also found aux...
Sounds like u have a bad fan for 1,Im sure who disconnected it may have found an expensive problem they didn't want to deal with (electrical, ac compressor etc) Good luck, have it ckd
Apr 07, 2017 | 1993 Mazda Protege
Fridge wont cool
Dismantle the light unit and remove same. Front cover 2 screws and difuser. Mark difuser for right way up. Remove screw covers to lower unit and remove four screws. Ease away unit breaking ice seal and unclip connections. Remove same. Defros with hair dryer or similar and then do the same with the removed unit. Clear away insulation from fan drain and defrost to dry condition. Replace as removed. The problem is it has to be repeated at intervals when the fan shows signs of founing. You will know by the noise. Paul.
Jul 11, 2010 | Amana ASD 2624 Side by Side Refrigerator
Fail to start
I think I would change the petrol in the tank as it may have become a bit stale. Also I would replace the battery.Make certain the replacement battery in fully charged before you try again.
Mar 17, 2010 | 2003 Triumph TT 600
PULLED FRIDGE OUT, REMOVED BACK PANEL, EVAPORATOR
Yes , motor is bad . May not start , next time cuts off . The fan in the back by the compressor , is called the condensor fan motor . I would suggest cleaning the coils in front at the bottom , of dust , lint , pet hair , etc , before replaceing the fan motor . Also , clean the fan blade before reinstalling the motor .
Sep 11, 2009 | Refrigerators
Heater fan stopped working
check the back of the fan switch for power and inspect it for damage ,melted or loose connections.
May 25, 2009 | 2002 Ford E350
Constant Rebooting and System Error Messages
I suspect you could have a heat sink fan not working remove side of case and when you turn computer on check fans heat sink and video card are working
With computer OFF
remove heat sink fan and check that the heat sink is not clogged up with fluff and dirt.
I regularly clean both fan and heat sink every 2 months also check the fan in power unit and blow it out
Aug 16, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Roper fridge not cold
That is then the first thing you will need to insure is running. The fan can be removed and checked. Now if the compressor is not running I would believe you have another problem. You can hear or feel the compressor running and the fan is usually connected to the compressor wiring so they both should be running at the same time. I have seen the fans run for a short period of  time after the refrigerator was turned off and then back on after cooling, so if stopped and starting of the condenser fan can at times trick you to believe the fan is OK
 Hope I have been helpful, Sea Breeze
Oct 28, 2007 | Roper RT21AKXKQ Top Freezer Refrigerator
Sony KDS-R60XBR1 60" Projection HDTV Logo
355 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
