Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
My question is , i have 4 Argus LCM PLUS PATIENT MO NITER AND THE PROBLEM IS DOESN'T WORK IN ALTERNATIVE VOLTAGE,IT IS ONLY WORK BY BATTERY after a weak the battery is low in the display.. PLEAS ADVICE ME. LOOKING FORWARD WONDWOSEN
    Top Expert:
  • 75,283 Answers
There are two supply systems are in your machines. One is for charging the battery, and other is for bypass AC power converted to Dc ; when AC power is present. That is when AC power is present, your machine will work on that power, and charge the battery simoultaneously. When AC power is inturupted, it will automaticaly change over to battery power. But the power consumtion of your machine is high. Therefore battery power will get downed soon. Battery is placed inside the machne only for urgent power faulure use. Not for continous use. Both the power supplies are SMPS [Switched Mode Power Supply] types. We can't prophet the reason for its failure. We are repairing such machens here. Now your machines battery charging circuit is ok. AC power bypass is faulty.
Email; gopakumarg43@ymail.com.
gopakumar1@hotmail.com
Trivandrum, Kerala.
Posted on Oct 14, 2010
Can't find alternator relay in 2004 Kia Spectra
There is no alternator relay . You more then likely have a resistance problem in the wiring for the alternator . Or bad ground . Check out this video on voltage drop testing . Voltage Drop Testing the Charging System Plus check battery cable connections .
Jun 10, 2016 | 2004 Kia Spectra
Right low beam headlight does not come on but my right turn signal will stay even tho i diddnt turn it on. If I cut on my high beams the rurn signal cuts off. Whats wrong? Helo
It could be the lamp control module !
Headlamps
Battery positive voltage (B+) is applied at all times to the lamp control module (LCM) through the underhood fuse block HDLP fuse.
When you place the headlamp switch in the HEAD position, the headlamps input to the LCM is grounded. The LCM then applies battery positive voltage (B+) through the underhood fuse block HDLOBML fuse and HDLOBMR fuse, which feed the left low beam headlamp and the right low beam headlamp respectively. When you activate the headlamp dimmer switch by pulling on the multifunction lever until the switch clicks, the high beam input circuit to the LCM in grounded . The LCM then removes battery positive voltage (B+) from the low beam headlamps and supplies battery positive voltage (B+) through the underhood fuse block HDHIBML fuse and HDHIBMR fuse, which feed the left high beam headlamp and the right high beam headlamp respectively.
Check this fuse in the left under hood fuse box first. HDLOBMR Fuse 18 10 Amp. RH Low Beam Headlamp . If the fuse is good check for B+ voltage with the low beams on . Use a test light or volt meter . If you look on top of fuse there are two metal tabs ,check there for B+ voltage , If no B+ voltage the LCM - lamp control module isn't supplying any .
Lamp Control Module (LCM)
Under the left side of the IP, to the right of the steering column
Turn Signal Flasher
Lighting Systems Component Views in Lighting Systems
Lighting Systems Connector End Views in Lighting Systems
Turn Signal/Hazard Switch
In the left front of the passenger compartment, in the steering column
Apr 28, 2016 | 2000 Buick Park Avenue
How to use an argus aa500p on 8 volt battery
www.argus.info/.../argus...//022_ARGUS%20142_Manual_U_V_2_10.p..
Should be simular
Jun 13, 2014 | Argus AA500P Professional Digital Battery...
Replace dimmer switch
The headlamps ( high an low ) are controlled by the LCM lamp control module .
Headlamp Dimmer Switch
Under the left side of the IP, on the base of the steering column
Headlights Circuit Description (Buick)
Battery positive voltage (B+) is supplied at all times to the lamp control module (LCM) through the LH underhood fuse block LCM/HDLP circuit breaker via CKT 242 (RED). When the headlamp switch is placed in the ON position, the headlamp switch input to the LCM is grounded via CKT 103 (WHT). The LCM then supplies battery positive voltage (B+) via CKT 12 (TAN) to the following components:
• Left low beam headlamp
• Right low beam headlamp
When the headlamp dimmer switch is placed in the HIGH position, the LCM removes battery positive voltage (B+) from the low beam headlamps. The LCM supplies battery positive voltage (B+) via CKT 11 (LT GRN) to the following components:
• Left high beam headlamp
• Right high beam headlamp
The LCM provides battery positive voltage (B+) to the appropriate headlamps under the following conditions:
• The ignition switch is in the RUN position.
• The ambient light sensor indicates darkness.
The lamp control module (LCM) monitors the ambient light conditions through the ambient light sensor. The ambient light sensor is a variable resistor whose resistance changes as the surrounding ambient light level changes. As the ambient light decreases, the resistance of the ambient light sensor increases. The LCM measures the resistance across the ambient light sensor and determines whether it is day or night.
Search from over 10 Million Auto Parts
Do you know how to test automotive electrical circuits ? Check power in an power out . Videos on youtube on basic automotive electrical testing .
Mar 08, 2017 | Buick LeSabre Cars & Trucks
2001 Lincoln towncar signature....PROBLEM:power door locks-trunk release-driver side power seat-keyless outer door entry-radio&clock......when weather is hot, door locks-trunk release-power seat-keyless...
What mechanics ? No codes stored in driver door module or power seat module ? Or don't these mechanics know about that ?
Did you try the dealer ?
Diagnostic Trouble Code (DTC) Chart DTC Description Source Action B1201 Fuel Sender Circuit Failure HEC Module REFER to Section 413-01 . B1204 Fuel Sender Circuit Short to Ground HEC Module REFER to Section 413-01 . B1205 Failure (Open or Short to Battery) HEC Module REFER to Section 413-08 . B1208 HEC Switch-1 Assembly Circuit Short to Ground HEC Module REFER to Section 413-08 . B1213 PATS Number of Programmed Keys is Below Minimum HEC Module REFER to Section 419-01 . B1231 Longitudinal Acceleration Threshold Exceeded RCM REFER to Section 501-20B . B1232 PATS Bad Diagnostic Byte Received HEC Module REFER to Section 419-01 . B1249 Blend Door Failure EATC Module REFER to Section 412-00 . B1251 Climate Control Air Temperature Internal Sensor Circuit Open EATC Module REFER to Section 412-00 . B1253 Climate Control Air Temperature Internal Sensor Circuit Short to Ground EATC Module REFER to Section 412-00 . B1255 Climate Control Air Temperature External Sensor Circuit Short to Battery EATC Module REFER to Section 412-00 . B1257 Climate Control Air Temperature External Sensor Circuit Short to Ground EATC Module REFER to Section 412-00 . B1261 Climate Control Solar Radiation Sensor Circuit Short to Ground EATC Module REFER to Section 412-00 . B1312 Headlamp Input Circuit Short to Battery LCM REFER to Section 417-01 . B1317 Battery Voltage High HEC Module REFER to Section 414-00 . B1317 Battery Voltage High RCM REFER to Section 414-00 . B1317 Battery Voltage High Air Suspension Module REFER to Section 204-05 . B1318 Battery Voltage Low HEC Module REFER to Section 414-00 . B1318 Low Ignition Voltage During Speed Control Operation NGSC Module REFER to Section 310-03 . B1318 Battery Voltage Low Air Suspension Module REFER to Section 204-05 . B1318 Battery Voltage Low RCM REFER to Section 414-00 . B1322 Door Ajar LF Short to Ground DDM REFER to Section 501-14B . B1334 Decklid Ajar Rear Door Circuit Short to Ground LCM REFER to Section 501-14B . B1340 Chime Input Request Circuit Short to Ground LCM REFER to Section 501-20B . B1342 ECU is Defective ABS Module CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ABS Module. REFER to Section 206-09 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective ACM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ACM. REFER to Section 415-01 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective CPM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new CPM. REFER to Section 419-08 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective DDM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new DDM. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective DSM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new DSM. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective HEC Module CLEAR and DOCUMENT the DTCs. PERFORM the HEC self-test. If DTC B1342 is retrieved, INSTALL a new HEC Module. REFER to Section 413-01 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective LCM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new LCM. REFER to Module-Lighting Control (LCM) in this section. CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective NGSC Module CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new NGSC Module. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective Air Suspension Module CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new air suspension module. REFER to Module-Air Suspension in this section. CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective RCM REFER to Section 501-20B . B1352 Ignition Key-In Circuit Failure LCM REFER to Section 413-09 . B1359 Ignition RUN/ACCY Circuit Failure LCM REFER to Section 211-05 . B1396 Power Door Lock Circuit Short to Battery DDM REFER to Section 501-14B . B1397 Power Door Unlock Circuit Short to Battery DDM REFER to Section 501-14B . B1402 Driver Power Window Down Circuit Failure DDM REFER to Section 501-11 . B1445 Door Handle Circuit Short to Ground DDM REFER to Section 501-14B . B1446 Wiper PARK Sense Circuit Failure LCM REFER to Section 501-16 . B1484 Brake Pedal Input Open Circuit ABS Module REFER to Section 206-09 . B1485 Brake Pedal Input Circuit Short to Battery LCM REFER to Section 417-01 . B1526 Keyless Entry Circuit Short to Ground DDM REFER to Section 501-14B . B1529 Memory Set Switch Circuit Short to Battery DDM REFER to Section 501-09 . B1533 Memory Position No. 1 Switch Circuit Short to Battery DDM REFER to Section 501-09 . B1537 Memory Position No. 2 Switch Circuit Short to Battery DDM REFER to Section 501-09 . B1545 Seat Direction Switch Assembly Circuit Short to Battery DDM REFER to Section 501-10 . B1549 Power Window Master Circuit Short to Battery DDM REFER to Section 501-11 . B1553 Decklid Release Circuit Short To Battery DDM REFER to Section 501-14B . B1555 RUN/START Input Circuit Failure LCM REFER to Section 211-05 . B1556 RF, LR, RR Door Ajar Circuits Short to Ground DDM REFER to Section 501-14B . B1569 Headlamp High Beam Circuit Short to Battery LCM REFER to Section 417-01 . B1577 Parking Lamp Input Short to Battery LCM REFER to Section 417-01 . B1581 Panel Dim Increase Input Circuit Short to Battery LCM REFER to Section 413-00 . B1585 Panel Dim Decrease Input Circuit Short to Ground LCM REFER to Section 413-00 . B1600 PATS Key Problem - No Key Code HEC Module REFER to Section 419-01 . B1601 PATS Received Non-Programmed Key Code HEC Module REFER to Section 419-01 . B1602 PATS Received Invalid Key Code Format HEC Module REFER to Section 419-01 . B1663 Driver Seat Front Up/Down Motor Stalled DSM REFER to Section 501-10 . B1664 Driver Seat Rear Up/Down Motor Stalled DSM REFER to Section 501-10 . B1665 Driver Seat Forward Backward Motor Stalled DSM REFER to Section 501-10 . B1666 Driver Seat Fwd/Bwd Recline Motor Stalled DSM REFER to Section 501-10 .
Also do there know anything about serial data bus ?
Plus , do they know what voltage drop testing a electrical circuit is . I should find better mechanics .
May 31, 2017 | Cars & Trucks
Twilight sentinel will not work; now headlight and tail lights won't come on; interior lights still work with knob. Do you think it is the F-switch? Also, where can I get a schematic of how to ins
It's probably the lighting control module , but without doing some electrical testing that is just a guess !
Battery positive voltage (B+) is applied at all times to the lamp control module (LCM) through the underhood junction block HDLP MaxiFuse® and CKT 1242 (RED).
When you place the headlamp switch in the HEAD position, the headlamps input to the LCM is grounded. The LCM then applies battery positive voltage (B+) through the underhood junction block HDLOBML fuse and HDLOBMR fuse, which feed the left low beam headlamp and the right low beam headlamp respectively. When you activate the headlamp dimmer switch by pulling on the multifunction lever until the switch clicks, CKT 524 (PPL) is grounded to the LCM. The LCM then removes battery positive voltage (B+) from the low beam headlamps and supplies battery positive voltage (B+) through the underhood junction block HDHIBML fuse and HDHIBMR fuse, which feed the left high beam headlamp and the right high beam headlamp respectively.
Twilight Sentinel Circuit Description
Twilight sentinel determines whether the daytime running lamps (DRL), or the exterior lamps and the low beam headlamps at full intensity should be on based upon the signal of the ambient light sensor. When the ambient light sensor detects daytime, the twilight sentinel turns on the DRL. When the ambient light sensor detects darkness, the twilight sentinel turns on the exterior lamps and the low beam headlamps at full intensity. The twilight sentinel also keeps the lamps on for a delay period of 3 to 180 seconds under the following conditions:
• The vehicle is in PARK.
• The ambient light sensor detects darkness.
• The ignition switch is turned to the OFF position.
You may turn off the twilight sentinel manually. When it is dark and the gear selector is in PARK, pushing the twilight sentinel switch to OFF will turn off the headlamps and exterior lamps. Pushing the twilight sentinel switch to OFF again will turn on the headlamps and the exterior lamps. If the gear selector is not in PARK, pushing the twilight sentinel switch will have no effect.
The F- switch is just an input from the LCM - lamp control module .
Do you know how to test control module inputs an outputs ? Very easy to fry a module if you don't know how to do it .
Also have a full scan of all modules on the vehicle , could have DTC'S - diagnostic trouble codes stored . Not for the OBD 2 engine computer . The instrument cluster , BCM , LCM can all set codes too, related to lighting an someother thing's .
ECM Inputs and Outputs Diagnosis
Electric Testing Techniques You Need to Know
You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine ! Under system click on lighting ,then under subsystem click headlamps . Click the search button then the blue link . The first diagram you will see at the top the power supply to the LCM , down a little you will see the headlamp switch , ambient light sensor . Now if you want to start replacing thing's without testing good luck !
Jun 02, 2017 | 1997 Buick Park Avenue
Battery tested no good, replaced it, next day battery wont start car, noticed blown fuse at postive terminal, replaced it, jump started car, working fine ...... Question, will that fuse prevent battery...
the fuse must be 'intact' for electrical system to operate properly.batteries are rated in months as far as longevity is concerned,36 mo. 60 mo. etc. if you have or have access to a volt meter,battery voltage should be 12 volts with engine off,13 to 15 volts w/ engine running indicates alternator is working.
Oct 17, 2009 | 2001 Hyundai Sonata
My camera argus dc-5195 doesn't turn on it works plug in the computer i try changing the batteries and nothing
ok the problem is that you kniow the thinki tha sayys + and - in there that litle metal can cause the problem or some wire maybe disconected.
May 30, 2009 | Argus DC-5195 Digital Camera
Changed battery now clock blinks when lights are on''
it may be the very expensive lighting control module. $250 from tascafordparts.com.
It is under the dash just above the brake pedal behind the sound panel.
couple of tests for you.
A15 CHECK DIMMER SWITCH OPERATION
  • Using a voltmeter connected to a known good ground, check for voltage to Circuit 1036 (BR/W) from headlamp switch.
  • Operate dimmer switch to LOW setting.
  • Operate dimmer switch to HI setting.
  • Using a voltmeter, check for voltage to Circuit 1035 (O/R) from headlamp switch.
  • Is voltage present on both circuits?
ssa~us~en~file=arrow.gif~gen~ref.gifYes
GO to A16 .
ssa~us~en~file=arrow.gif~gen~ref.gifNo
If ground circuit to headlamp switch is good, REPLACE open headlamp dimmer switch. RESTORE vehicle. RETEST system.
A16 CHECK FOR DIMMER INPUT TO LCM
  • While operating dimmer switch, connect a voltmeter to ground and alternately to Pin B16, Circuit 1035 (O/R) and Pin B15, Circuit 1036 (BR/W).
  • Is voltage present alternately at both circuits?
REPLACE lighting control module (LCM). RESTORE vehicle. RETEST system.
SERVICE circuit(s) in question for open/shorted circuit(s). RESTORE vehicle. RETEST system.
Mar 12, 2009 | 1995 Lincoln Town Car
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
2,124 people viewed this question
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Tom Chichester
Are you a Schiller Medical Expert? Answer questions, earn points and help others
