Question about Samsung HLS4676S Television
I HAVE A HLS4266W AND I HAVE WHITE DOTS ALL OVER MY PICTURE . HOW DO I GET THEM REMOVED ?
  • Samsung Master
  • 6,993 Answers
This is not as easy as you think. I had the same thing happen to one of my flat panel monitors and called up Samsung, since it was still under warranty.
Each pixel is lit up, all of them converge to form the picture you see. When that pixel "dies" or goes out, you will see nothing but the white, thus the little white dots on the screen.
Samsung told me they would replace the monitor, that fixing the problem would be cost prohibitive, i.e. more than the monitor originally cost. The entire board would have to be replaced.
So I would suggest you take the TV to a local repairer to fix the problem for you.
Good luck.
Posted on Oct 13, 2010
Black and white pixels increasing in number in my picture
The DMD chip is failing on your projection device. The only way to fix it is to replace the chip. The dots are usually caused by excessive heat build up.
http://www.youtube.com/watch?v=BYJTF3yZYVY
Home IPS LaserExpress
Dec 27, 2013 | Dell M210X DLP Projector
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
Open Questions:
Samsung HLS4676S Television Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
