Question about Toshiba 42HDX82 42" Rear Projection HDTV-Ready Television
HI. i just bought the TV -USED - and the sound does not work. Turned all the way up on the remote and TV. You can barely hear it. Is it worth fixing? thanks Teresa
Change the inputs cables on the back of the TV and see if that helps. You will have to go in the menu of the tv and change it to. 1st turn down the volume of the tv.
Posted on Oct 13, 2010
I can not hear the sound on my Sylvania tv.
is it only with the xbox? how did you hook it up/
Feb 18, 2015 | Sylvania Televison & Video
Panasonic tv goes blank after a few seconds when turned on no sound or vision, have to turn off and back on to work
the voltage regulator is probably going back. may or may not be worth it to fix. TVs are bigger better and cheaper now
Mar 12, 2014 | Apple iPhone Cell Phones
I have an RCA F31672ET TV. It was working fine for many years. Then all of the sudden it will not turn on with either the remote or the power button. I thought of using a universal remote to try and turn...
Hi - pretty common problem. Not worth fixing, I'm afraid. It is caused by a defective circuit which became defective with old age. the "EEPROM."
Feb 27, 2011 | RCA F31672ET TV
MY GRANDDAUGHTER TURNED ON/OFF OUR T.V REPEATEDLY NOW THE TV WILL ONLY TURN ON OR OFF AFTER UNPLUGGING, WHEN THE TV COMES ON IT IS STUCK ON 1 CHANNEL AND YOU CAN'T ADJUST THE CHANNELS OR THE VOLUMN. DO NOT...
Try website like Remote.com to buy an original remote.Might still can used it with a remote.Tv might have shorted or dead,it power switch losely,tries press it turn power on now?Yes,tv worth repairing a swtich or PCB manual control board functions,just require replacing.
Feb 08, 2011 | Memorex MT201224 20" TV
Cannot hear the sond on Sylvannia TV 6615LCT
This will sound strange, but some DVD players and cable boxes have separate volume controls. I would check the settings for both of those to make sure that the volume has not been turned down and also check the connections from the dvd player and cable box to the tv. Make sure all connections are solid.
Apr 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Sound
just try and reinstall your driver for the sound device and check again
Mar 16, 2008 | Edirol UA-4FX External Sound System
No Sound
hi there, it maybe the jack were you used headphones, try to replace the jack and see if there are some cold solder at the amplifier section. test some parts. ty
Dec 29, 2007 | Memorex MT2206 TV
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 42HDX82 42" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
