Question about Frigidaire FWS833A Top Load Washer
I NEED TO FIND THE PART NO. 64484424 FOR MY MODEL FWL22SA I GET THE CLOTHS IN THE WASHER AND HAS THE FIRST SPIN BUT THE MACHINE THROWS OUT THE CLOTHS.
  • 3 Answers
I need actuactor # 64484424 for Electrolux washer mo. FWL22E
Posted on Jan 26, 2014
  • 1028 Answers
SOURCE: new washer violant spin cycle,even
ck to be sure shipping rod has been removed you will need to pull washer out and look for a pin through a rod that runs from 1 side to the other pull it completely out relevel washer if needed
Posted on Aug 11, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore top load washer spin problem
its possible you have a bad clutch assy, or perahps something stuck between the outer and ineer tub(i.e. sock) preventing free spin of unit, the clutch is mounted on top of the transmission assy and requires a little bit of work to acess, im sure you can find a video on you tube as to how to acess that
Posted on Oct 19, 2008
MNTECH
  • 1543 Answers
SOURCE: washer doesn,t spin
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
Posted on Oct 27, 2008
  • 7 Answers
two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
Posted on Oct 28, 2008
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Need manual for maytag washing machine model As11
probably needs a belt. pull the washer from the wall and tilt it back against the wall, make sure it is stable. then look under and find the belt and replaced from a local vendor.
Jan 02, 2012 | Maytag VRSCDX Night Rod Special Washing...
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The machine won't spin some times. Some times it won't spin the clothes enough to get the water out of them.
Make sure you don't have the washer loaded to much with cloths. If there is to much cloths the washer will not spin, because of the heaviness.
Nov 28, 2009 | Kenmore Washing Machines
I have a Kenmore Elite cloths washing machine Model #110.24962300. in the last month there was a noise when the washer was finishing its spin cycle. today it will not spin if there are cloths in the...
First open the filter door and remove the water from the machine and the "garbage".
Second the problem sometimes is the water pressure, you have to control the amount of water.
Kenmore Elite is a sensitive machine level the machine.
IT´S NOT A ELECTRONIC PROBLEM
Regards, Pedro from Portugal..
Nov 19, 2009 | Kenmore Washing Machines
Need help please with washer machine,wont spin my cloths,just drn
a belt has snapped or came off or the motor and brushes are damaged.
Sep 20, 2009 | Maytag MTW5700TQ Top Load Washer
Machine will not spin water out of cloths.
A tranny or clutch problem is typically associated with a complaint of "the washer will not spin"
If you're complaint is now "washer will not drain" (you can see water at bottom of tub at end of cycle); I would check and test the water pump and ensure your drain-line is clear (machine & house-line). Note: You can double-check by having your washer drain into a bucket or something (outside).
You may have a defective pump / pump impeller which will not give the amount of pressure needed to drain completely (broken blade or something).
What was your original problem? Who advised it was the tranny/clutch? Does your washer have a belt?
Jan 27, 2009 | GE WBSR3140DW Top Load Washer
Jan 17, 2009 | LG WM1814CW Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
