Question about Ovens
The microwave in our trailer quit working and it gave a code 1.00,could you possibly give me an answer to what the problem could be. Thanks
  • 1,711 Answers
What brand and model
Posted on Oct 13, 2010
  • espressonist
    espressonist Oct 13, 2010
    Also confirm how excactly the code is written
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
The fan works but the oven doesnt heat up
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jul 13, 2011 | Whirlpool Ovens
Microwave will not heat. Turntable does not move. Lights come on and fan is working. Ideas?
Apr 14, 2011 | Ovens
The lightbulb in the microwave needs to be replaced. How does one get at the bulb to change it?
At the following site, http://www.ehow.com/how_4967054_change-light-bulb-microwave.html
detail instructions can be found for changing the light bulb in your microwave.
Give it a try.
If this works for you, please give me some positive feedback.
Thanks!!
Jan 25, 2011 | Ovens
Looking for user manual sharp microwave 900watt model r343
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://micromatikal.dlinkddns.com:8000/cust/r343.PDF
Oct 15, 2010 | Ovens
I was defrosting meat in the microwave and my microwave just quit. The fuse box was checked. MY microwave is blank. What is the problem?
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Oct 09, 2010 | Ovens
Troubleshooting a microwave problem
Linda:
replace the membrane keypad
Nov 02, 2009 | Ovens
Got a Turbochef tornado that has a faulty door (won't shut properley) i'm based in Liverpool England and need an engineer or solution to fix the problem, i have fallen out with marren so need an...
is the door sitting straight or does it look out of line.with out seeing the oven it is hard to give you an honest answer,please give me a call on 07986184154 and i will try to give you a better answer after asking you a few questions,regards les from lsg microwave services
Jul 10, 2009 | TurboChef TORNADO Electric Oven
F-7 ERROR CODE
sir,
check these links
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
May 21, 2009 | Jenn-Air JMW8527C Electric Double Oven
Electric oven model 790.47892601
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 28, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
