Question about AutoZone
What is the correct timing for a 1976 f250 390 4x4 6.4 Ford truck?
1976 Ford F 100 turn signals don't work
If you put a test light on the flasher, will it continue to flash ?
And do the emergency flashers work correctly ?
Sep 19, 2015 | Ford Cars & Trucks
How can i stop my 1976 dodge aspen wagon from sputtering while idling
Check your power booster Vacuum line, your Timing, check if your plug wires are correctly installed, check for properly gaped plugs, Fuel Filter may be clogged if vehicle sat for an extended period of time, try using a high octane fuel the first couple of tanks.
Jun 16, 2014 | 1976 Dodge Aspen
Ford f250 1976 heater motor location
usually under the dash, in behind the front bulkhead/firewall
Apr 02, 2014 | 1968-1976 Ford F250 Truck Distributor...
Need 1976 Ford Ranchero vaccum diagram
That should be the same as a Torino and maybe a 77 Thunderbird. You might try the library or search engines for a shop manual for those models.
Jun 22, 2012 | Cars & Trucks
Will a 1976 ford f100 front suspention fit under a 1976 ford f250
Yes and No
Yes if you the knowledge of welding gussets for the larger bushings it takes.
No if you do not have a welder and the materials to make your own new parts to attach
May 17, 2010 | 1981 Ford F 100
I need to know what smog equipment the 1976 ford F250 had on it to pass the Ca smog requirements
None. Yes I said it right, None. Belive it or not in 1976 trucks were not required converters, air pumps and could run on leaded or unleaded gas. Man I've been doing this too long and I'm getting old.
Dec 03, 2009 | 1990 Ford F150
Ford cortina manual
http://www.books4cars.com/
hi, have a look on this site.....hope it helps
please leave feedback on fixya for me, as i do this for free in my spare time
Jul 28, 2009 | Ford Focus Cars & Trucks
Require ford escort rs 2000 1976 torque settings head bolts
2lt overhead cam with them horrible tappet adjusters,cast iron head but valves dont hit the head if the timing belt breaks ,but it does on the 1600 .called a pinto in america .Remember the assembly line well ,have many a fond memory of working on it and the staff canteen on night shift ,what lovely grub we got.Head bolt torque is about 80lbs because i used to pull them down to check them after the machine had tightened them up
Apr 24, 2009 | 1997 Ford Escort
How do I set timing on 1976 suzuki gt 380
Send me your e mail address to jonathangreen123@btinternet.com I wrote an essay on how to solve your problem and ran into trouble getting this site to accept it. I'll tell you all you need to know. For goodness sake don't give the engine the slightest bit of throttle abuse until you have set the timing correctly. If you do, you run the risk of holing a piston.
Feb 01, 2009 | 1976 Suzuki GT 380
AutoZone Logo
90 people viewed this question
Top AutoZone Apps Experts
Erin Wood
Erin Wood
Are you an AutoZone App Expert? Answer questions, earn points and help others
