SOURCE: hi! I have a problem
You have tried re-setting it, Right?
What happened when you did?
Note: This problem ended up under Vacuum cleaners-
You might want to try re-listing it again-- under Electronics?-
Mack B
SOURCE: I have an older model
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
SOURCE: How to set the alarm
The emerson smartset is a wonderful unit. You can set 2 different alarms on it so it wakes you up at different times on weekdays and weekends. How to achieve this is addressed in pagesd 6-10 of the user manual. Here is a link to help you download the user manual.
http://www.servicemanuals.net/freemanuals/CKS2237ibrev.pdf
Hope this solution has been helpful?
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
