Question about Chamberlain Standard Duty Polisher/Waxer
I have a Polishmaster 1900 and the pads have delaminated. Where can I get a replacement pad set? Is it worth the cost or should I just buy another polisher?
2 Suggested Answers
  • 20 Answers
SOURCE: I have a Waxmaster 900 type 2 auto polisher by
try machine mart
Posted on Jul 31, 2009
My PS3 controller won't go to the right. Help!
The problem could be as simple as a loose connection .. Control pads are fiddly and can get very frustrating I ended up buying a new pad as I figured that the stress wasn't worth the cost of a new 1 but 1 of my pads used to pull to the right constantly and the problem was solved by taking the pad apart and simply cleaning the inside and making sure all wires was connected .. Sorry I couldn't be more help
Aug 25, 2012 | PDP Afterglow AP.2 Wireless Controller for...
Tip
High Dollar/High Mileage Brake Pads,Verses OEM,Or Metallic Pads
What is the big talk about high mileage brake pads?Well,they do last a really long time,they actually do,but,yes ,I say but,did you know that the high mileage pad is a lot harder too,and this includes the ceramic pad also,witch is a pad designed to stop,all brake dust,so your rims will stay clean and shiny.This is all good,but two,no,three things are on the down side of the harder brake pad.One,as you drive,the brake pad does not give,any,it just continues to mill away at the brake rotor,there fore,most of the time,when it is time for a new set,witch will be a good long time,the rotors are too far gone to resurface,and must be discarded,and then you have to replace them with new ones,even at a bargain,they,the rotors will cost a lot more than a set of OEM,or semi metallic brake pads.Two,They will not stop as well,it can take as long as twice the time to come to a full stop,when applying the brakes.Three,the premium brake pad can cost as much as 90.00 dollars,compared to as low as 18.00 dollars for a OEM ,or semi metallic brake pad,you could almost buy 5 sets of brake semi metallic for one set of premium brake pads.You choose,how much money do you want to put into your brakes?Face it folks,a little dust can wash off,compared to having to pay out the nose just to not have the brake dust,and putting money into rotors every time you do a brake job. I am going to let you in on a secret here,the manufacture advertises life time warranty for these premium pads,but they do not warranty the rotors,and the labor,and it is hard now,to get them to warranty the brake pad.Weigh the difference,is it worth it.You make the call.
on Jul 15, 2010 | Chevrolet C2500 Cars & Trucks
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
Need good front brake pads
Pads come in various quality and price. Good pads are a bit costly but worth it, ask you parts person for the premium quality pads and ask him/her why they are better than the lower cost pads
Apr 07, 2010 | 2003 Jeep Grand Cherokee
Rear brake pads wear out every 30000 miles on 2002 3/4 tod hd , rotors are pitted bad
That's to be expected and is completely normal.
Rear brake shoes as fitted to drum brakes can typically last up to 60k miles with periodic adjustments, but you have rear disc brakes and the shoes will typically last half of that.
Also, modern brake pads no longer contain asbestos and are now made using harder metallic compounds; the direct result is that brake discs (US=rotors) are also considered to be consumable items as they are worn down by the harder pads. It's not unusual to have to replace front discs every other pad change and rear ones with every pad change; in both cases the mileage will typically be around 30k miles on most models.
Nov 15, 2009 | 2002 GMC Sierra 2500HD
Brakes
Your routers are going bad or your pads need to be replaced.
More than likely its your routers see if you can get them resurfaced at a shop.
Aug 18, 2009 | 1992 Buick Park Avenue
What cost to buy and put on 4 brake rotors please on audi A4 1996
there prob about 30.00 each
plus you need too replace the brake pads about 18.00 a set
probly find some one too install it all for 50.00
ask at auto zone
Apr 28, 2009 | 1996 Audi A4
Chamberlain  Standard Duty Polisher/Waxer Logo
579 people viewed this question
Top Chamberlain Tools & Hardware - Others Experts
Are you a Chamberlain Tool and Hardware - Other Expert? Answer questions, earn points and help others
