Question about Hotpoint Dishwashers
No water is geting to dish washer - Hotpoint Dishwashers
    President:
  • 1,430 Answers
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Posted on Oct 13, 2010
  • 255 Answers
If you've not changed anything on your water system and you know that you have water pressure at the machine, the problem is in one of two things: The timer isn't turning on the hydromechanical valve, or it is the hydromechanical valve itself. Both of these are common problems that are easily solved. A tech call will be in order, or if you're handy, test these two items with an ohm meter for power to the valve. If you have power (this means timer is good - remember to set it on "fill") and can hear an audible click in the valve when you energize it (with water pressure attached), the rubber diaphragm is bad. If no click, something is wrong with the valve coil. Replace items as indicated. The entire valve will need to be replaced if either no click or click and no flow.
2 Suggested Answers
SOURCE: The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Posted on Dec 02, 2009
My lg dish washer leaves the dishes dirty and the soap is still in washer
check water hook up and its hooked up to hot water line or washer is not draining if water still there spray arms may be plugged up
need more info model # help
Dec 04, 2016 | LG Dishwashers
Water not heating
Dish washers only use water supplied from the hot water side of the pipes under the cabinet or sink, so if you installed the dishwasher yourself, be sure that you ran your inlet water line and connected it to the hot water side, and not the cold water side. The dish washer has heating elements inside the machine to dry the dishes, not heat the water. If this is hooked up correctly and you are still getting cold water to heat the dishes, the problem may be that the unit is too far from the hot water tank. In that case, you may need an auxiliary hot water tank installed near the dishwasher under the cabinet. They make small tanks for such purposes.
Dec 14, 2014 | Dishwashers
Dish washer runs all cycles but no water entering dish washer
Make sure you check that the water is turned on to the dishwasher.
Check for a kinked or squished fill hose. If all else fails its most likely you need a new fill valve for your dish washer.
Feb 28, 2013 | Maytag Dishwashers
How do you replace water intake hose on machine
under the kitchen sink there is a water valve that is attach to a hose that goes in behind the dish washer that feed the water to it,,,,the dish washer is attached to the counter by two screws in the front of it,,take them out and the you can slowly pull out the unit,,,to change out the water feeder hose,,but make sure you shut off the water going to the dish washer first
Feb 19, 2011 | Dishwashers
C check water light comes on it leaking water from
your main water line on dish washer has a crack in it in the very back so when wile washing dishes its not geting the right amount of water that it suppose to replace cuplen on bad peace of pipe.
Feb 14, 2011 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 13, 2010 | Maytag Dishwashers
We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
You have to buy a cartridge type water softener and attach it to the
inlet water line of your dish washer. In addition to this there must be
a salt compartment in the dish washer.
Refer the user guide /owners manual and locate. Fill it with the special
dish washer salt. ( Do not use kitchen salt used for food).
The dish washer salt may help to certain extent in softening the wash
tub water inside. Check the switch settings for rinse aid and salt
release settings in the machine. Refer manual!
Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
Apr 29, 2009 | Dishwashers
Water backs up to the dish washer from the sink .
Check the drain hose under the sink. It should have a high loop an upside down "u" like a hill the water can't climb to get from the sink to the dishwasher. That is where I'd start. Good luck.
Jan 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
88 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
