Question about Delta Faucet 522MPU Chrome 1-Handle Lavatory Faucet with Pop-up
No running cold water - Delta Faucet 522MPU Chrome 1-Handle Lavatory Faucet with Pop-up
  • 7,733 Answers
Look for a clogged cold water line.
Posted on Oct 13, 2010
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Cold water run into washer slowly. Pull off cold
water may flow fine through the hose itself, but you prob. have a damaged water inlet valve on the washer.. ( what the hoses are conected too... hope this helps...
Oct 27, 2009 | Washing Machines
Cold water won't run into washer. warm is fine,
Hello.
If the cold water will not run into your washer you will need to replace the water valve on your unit.
Jul 16, 2009 | Washing Machines
The cold water won't run anymore. The warm will run but no cold. Even in the rinse cycle.
The cold water supply valve can be bad, the cold water hose can be twisted and crimped, the selector switch for cold can be not operating or the water inlet filter < on washer end of hose can be plugged, the water valve for supply may be off or some other cause.Inspect cold water hose for crimping, disconnect both supply hoses and check for any debris on washer valves, run cold supply to verify it doesn't have a problem then problem exists within washer. From this point if you still have problem then you will need assistance to narrow down cause.
Apr 25, 2009 | Washing Machines
Turn on cold wash and no water will run.
It sounds like your cold water celenoid is going out. You have to replace the whole water valve. it should be around 30 bucks. your local parts store should have it in stock, Just take your model # with you.
Nov 21, 2008 | Maytag Atlantis MAV8551 Top Load Washer
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Delta Faucet 522MPU Chrome 1-Handle Lavatory Faucet with Pop-up Logo
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
