Question about IBM eServer xSeries 206
Attempting to upgrade xSeries 206 memory from 512 to 2x1Gb. Existing memory is PC2700 300 2.5CL Reg ECC in slot 1 New is PC3200 400 3CL Reg ECC. in slots 1 and 3. 3x3 beeps on bootup and blank screen. Have followed IBM advise and rebooted at least 4 times after upgrade but still 3x3 beep code on startup. According to manual the system should accept the upgrade. What else could I try. New memory is good, no faults.
  • 1 more comment
  • Michael Turner Oct 14, 2010
    The memory is brand new and has a life time warranty. I have tried a single chip in the original slot so that slot is clean. No joy which ever new chip I use in the original slot. The spec of the memory has exactly the same spec as that defined by IBM for the server. The only difference is that the memory is not sourced from IBM but from a server memory specialist in the USA. However the spec is as read from the chip and checking it against IBM specs it should work. I can accept one chip may be faulty but not both. Because I can only access the server a.m. on Mon, Weds and Fri I can do no further checking until tomorrow. However IBM have advised me to boot with all slots empty to zero out the BIOS and try again as that often then re-registers the memory, whatever size is inserted provided it is of the correct spec, which it is. Unless you have other ideas I can try tomorrow that is the route I will attempt. Also, I know no one with with a similar slot config so very much on my own on this one.
  • Michael Turner Oct 15, 2010
    Yes
  • Michael Turner Oct 16, 2010
    I await a comment from the memory supplier.
  • 6,993 Answers
this is as a result of memory error. The memory is either not compatible with your computer, or maybe you did not fix the memory well which is not making the computer not see the memory.
Cpu beeps most times if a memory is not present or not compatible with a the CPU.
Use a brush to clean or dust off the memory slot and try again. You can borrow a memory from your friend and test it with our cpu.
But I believe the memory you want to upgrade is not compatible with your CPU.
Good luck.
Posted on Oct 13, 2010
  • 1 more comment
  • Walesarumi
    Walesarumi Oct 14, 2010
    Is the previous memory still working with the IBM computer?
  • Walesarumi
    Walesarumi Oct 15, 2010
    Hi, if the previous memory still works then its not a memory slot problem but the memory itself. I mean the Ram might not be compatible. Or is the CPU locked to only one Ram? Its like the new Ram is not just clicking with your IBM. Its not a problem from either the Ram or IBM, but an incompatibility issue.
    Take care.
  • Walesarumi
    Walesarumi Oct 16, 2010
    Okay! I look forward to the outcome.
Blue screen when trying upgrade memory
If you are adding more RAM to the existing RAM then then new RAM maybe incompatible with the existing RAM. Use RAM that is the same specs as the existing RAM and from the same manufacturer.
Feb 15, 2013 | Computers & Internet
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
I want to upgrade the RAM to 1 gig in my evo 600c what memory should I get that will work? Ive put in a new 50gig hard drive but its really slow
Evo n610c Laptop
Maximun Memory 1024MB Non ECC
Unbuffered CL=2.5. DDR333
2.5V.
DDR PC2700
Number of Slots:
Slot 1 Slot 2
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot
I have the same laptop
Nov 02, 2010 | Compaq Evo N610C Notebook
I'm have one server ibm with 1Gb of ram and i want to upgrade but don;t know about it can be support thank for help!
Technology: DDR SDRAM - ECC, max 4Gb, Memory speed: 400MHz, Form factor: DIMM 184-pin, Memory Specification Compliance: PC3200
Jun 30, 2010 | IBM xSeries 206 Server
Do this model supporsts win xp service pack 2
Hi.
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
I am looking to upgrade memory on an MSI N1996 Mother Board which has 2x 168 pin slots and 2x 184 pin slots. I wish to know if I can go to 2GB and which memory is best to use, i.e. ECC,...
If your motherboard supports ECC, and you can afford the much-higher cost of ECC RAM, then buying/using ECC is "best".
Note that "buffered" memory is much slower than "unbuffered" memory.
Nov 05, 2009 | Intel Motherboard
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
IBM xseries 205, Model 8480-43X Memory upgrade an POST BEEP
Those beeps mean that your RAM is not functioning. Are you sure you got the right upgrade type. Sometimes it'll fit into socket but won't work because of speed. Or just try reseating the modules.
Jan 14, 2009 | IBM eserver xSeries 205 8480
Tried to upgrade RAM now computer won't boot up
check ther is 4 ram bank and if then fix ram after left 1 bank.then check .
there is also check frequency same of both ram.
Jan 10, 2009 | Computers & Internet
Upgrade graphics card in xseries server 206
You can use the PCI slot.
In a server, I prefer using ATI chip sets. They seem to be a lot more compatible with the systems.
Wart are you running for the OS?
Oct 18, 2008 | IBM Computers & Internet
IBM eServer xSeries 206 Logo
168 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
