Question about Desa International Reddy Heater® RHER155B Utility
Heater runs for approx.2 minutes then starts to blow black smoke
  • Desa Interna... Master
  • 43,501 Answers
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo orReddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Posted on Oct 13, 2010
Pentair minimax nt propane heater is blowing black smoke
is heater installed in a shed? how many btu's is your heater. You need 1 square inch per 1000 btu's for combustion air opening. Lack of combustion air will cause heater to under fire and produce carbon dioxide
Mar 16, 2014 | Pentair Minimax NT Heater
I HAVE A 170 REDDY HEATER THAT RUNS FOR APP.10 MINUTES AND QUITS BLOWING OUT BLACK SMOKE I HAVE CHANGED FILTERS AND CHECKED PRESSURE WAS AT6. PSI CAN YOU GIVE ME ANY HINTS
sounds like you have dirt in your fuel tank, as the heater runas it picks up the dirt in the filter plugging it up. When the heater shuts off, the dirt falls out of the filter. You start the heater back up and it does it all over again. Empty your tank and change the fuel filter. Should be fine then.
Feb 21, 2013 | Reddy Heater-170,000 BTU Kerosene Deluxe
Starts runs for a minute two the shuts down and blowes smoke
jerome kr406,
This is a classic problem with the reddy heaters. They have a filter which over time plugs up. This causes the air/fuel mixture ratio to change because the pump pressure is determined by the air bleed. As the filter plugs the air pressure drops and the fuel also drops meaning the burner is running lean. This eventually causes the unit to shut down and as you said smoke comes out. It is a fairly easy fix and I have a tip which will walk you through it at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters . My tip will link you to the place to get the parts you need as well as how to perform the additional maintenance that these heaters require.
Thanks for using FixYa and for the excellent rating. Great ratings help to keep experts helping everyone solve their problems. Thank you.
hardrocko
Nov 13, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
2004 Cadillac Escalade knocking noise
Make sure oil level is adequate.
Also, this could be an exhaust leak that is being closed as the manifold and/or block heats up.
Mar 02, 2009 | 2004 Cadillac Escalade
Portable heater blowing smoke on start up
Sounds like it is not burning all the fuel . If you have the manual it should tell you how to adjust air flow so it will burn wright. You might need to clean the nozzle that the oil comes out of. The manual will have the cleaning steps to if you have manual. If not i can try an find one for you.
Jan 18, 2009 | Dyna-Glo (PPH16-LP) Utility Heater
Scheu Heater problem
sounds like the fuel nozzle filter is clogged. remove it and blow air through it backwards or just replace the nozzle.
Dec 27, 2007 | Scheu (K350-FAT) Heater
Desa International Reddy Heater® RHER155B Utility Logo
182 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
