Question about Maytag MTB2156GES Top Freezer Refrigerator
The freezer stopped working, but the fridge part still seems to be ok.
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
The fridge part of the unit has stopped working i.e. cooling. The freezer seems ok. There is no coolnest or condensation od the back or side walls of the fridge unit
Hello
The fridge has lost gas or its dryer is blocked< you will need to have it looked at by fridge specialist
Thanks
Jun 08, 2011 | Refrigerators
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
MODEL RSH1FTSW side by side f/f Freezer seems ok but fridge stopped working what Can I do please
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 17, 2010 | Samsung Refrigerators
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Refrigerator isn't getting cold, but freezer part & ice maker seem to be working OK
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Refrigerators
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Maytag MTB2156GES Top Freezer Refrigerator Logo
148 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
