Question about Kenmore 24 in. 16019 Built-in Dishwasher
White powdery substance lift on dishes after wash.
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 13, 2010
Ruptured element. I recently called head office and I was satisfied to here that I am going to receive a new coffee maker do to a recall. my question how ever concerns a health matter as the element has...
no health risk as it is ceramic powder used as insulation around the wire that is the element proper in a copper tube
same powder as your ceramic dinner plates and cups
wash out thoroughly and rinse
Jun 28, 2017 | Bunn GR10 Coffee Maker
What would make my dishwasher leave a white powdery substance on the dishes?
The white film or powder can be caused by a couple things. Due to environmental laws, phosphates have been almost entirely removed from DW detergent. Phosphates were effective at preventing this. Also scale buildup on screens and in the pump can reduce the amount of water being pumped around. Use less detergent, try half filling the cups. In addition to the detergent put 1/4 to 1/2 cup of citric acid in the dishwasher and running a load. This will remove scale buildup. I use it about every other day. You can buy citric acid online, I bought it at thechemistrystore.com
Nov 12, 2010 | GE Nautilus 24" Built-in Dishwasher
I have a white powdery substance left on my dishes and they are not cleaning properly
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Oct 11, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The dishes are coming out all cloudy and seem to have a film on them. It is a powdery substance that will not wash off even by hand. It is ruining my dishes. It doesn't matter what soap I use.
Be sure to use a good quality detergent or tablet with rinse aid built in... but before that I would go buy a dishwasher cleaning solution. These are usually in a bottle and you just sit the bottle in the dishwasher by itself (with no other dishes) and run a normal washing cycle. The cleaner will clean the inside of the dishwasher, including the drain area and help produce cleaner dishes thereafter. This should be done every 3-4 months as standard.
Aug 19, 2009 | Whirlpool 24 in. Portable Dishwasher...
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Having a problem with a white powdery substance Model 17602
The sump may be full of debris here is how to check it:
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 28, 2008 | Kenmore 24 in. 17602 / 17604 / 17609...
Kenmore 24 in. 16019 Built-in Dishwasher Logo
154 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
