Question about GE Dishwashers
DISH WASHER DISHCHARFE MAY BE PARTIALLY PLUGGED- RECENTLY GETTING LARGE FLOW THRU OVERFLOW IN SINK PURCHASED VIA SEARS- INSTALLED AUGUST 30, 2007
  • etton Jun 01, 2008
    MODEL GLD 5760 N0055
    SERIAL # HM 803057B
    Genius:
  • 3,422 Answers
HI,
It's probably your air vent/overflow. You likely have hard water and the hose is limed up. Depending on set up you may be able to clean it without taking anything apart, or you may have to unclamp the hose under your sink. Use a product like C-L-R or Lime-A-Way (or vinegar in a pinch), let it sit for an hour or so. Heavy deposits will take several applications.
Goodluck,
Please don't forget to rate or accept the solution
Posted on Jun 01, 2008
    Sergeant:
    Champion:
  • 310 Answers
Its in warranty........
Just installing my blanco sink strainer. Can't figure out how the large washer black should be installe
The large black washer is installed against the bottom of the sink and the lock ring is installed next to form a leakproof seal.
Jul 14, 2017 | Blanco Plumbing
I have a Sears 22 inch lawn mower, model #917.376070, Serial number 121906M-029886. I recently purchased and installed a new blade from the Sears parts store in Milwaukee (part no. 917-141114) and...
The blade only cuts on the outer 4 inches of the blade rotation(diameter). As the mower moves forward, it cuts the full width of the deck. If sprigs of grass are missed or excessive vibration is present, you may have a bent crankshaft. Check and be careful, ejection of the blade hazard exist.
Jul 17, 2017 | Computers & Internet
Any way to bypass the W10156252 pressure switch? The OEM part number is now W10415587, and is not available until August, 2011. The wiring diagram doesn't give details of the switch. Model...
No you cant bypass the switch. what it does is to stop the flow of water comming in to the washer.
if you short it out water will not turn off and it will overflow. it you open it up you will get no water.
Are you sure the switch is bad. A common problem is that the hose that it is attached to it gets plugged up. have you tried to blow through the hose to see if it is clear.
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Jul 08, 2011 | Kenmore Elite HE5t Washer
The waste water backs up into the dishwasher when sink is plugged
Dishwasher manufacturers recommend a syphon break be fitted - but usually there is not a problem if your sink has an overflow pipe incorporated.
You have a partially blocked drain - causing wastewater to flow into the dishwasher instead.
Use 1/2 a cup of caustic soda or proprietary drain cleaner down the sink drain. Add about a pint of water, and leave overnight.
Next morning pour a full boiling kettle down the drain which should move things on and clear the drain.
You may have to repeat this process once, but is preferable to taking your pipework apart - which is next if this does not clear it.
Sep 14, 2009 | Dishwashers
My stainless steel dishwasher smells
You need to check to see if the drain line runs from the dishwasher pump to either a "T" on your kitchen sink drain or if it connects directly to the garbage disposal. Either connection is okay. However, water can run downhill from either connection to your dishwasher. To prevent dirty water from your sink or garbage disposal from running downhill to the dishwasher, you may have to install a dishwasher air gap. This can be purchased at a appliance parts store or a home improvement store like a Home Depot or Lowes. It is a "Y" shaped device that should be installed above the dishwasher drain line connection under the sink. As water will not run up hill, you need to make sure that the Air Gap is installed higher than the drain line's connection under the sink. "The Air Gap device should be mounted as high as you can under the sink."
Aug 22, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Breather for the dish washer
Yes the breather can be placed under the sink. Just be sure to mount it above the level of the dishwasher. You can either screw it to something wood or use tie straps to tie it up to a screw.
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher drains into sink
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Dec 31, 2007 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwashers Logo
64 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
