Question about KitchenAid KBRP20ERSS Stainless Steel
Just took delivery of a kitchenaid fridge model kbfs22ewms3 problem how to hook up water line to fridge the instructions are confuseing two plastic lines comeing from top of fridge one into a red cover the other into a connector unit which one does the copper feed line go to and if it goes to the unit at the bottom of fridge what do you do with the disconnected line that was taken out thanks Roy
SOURCE: Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Posted on May 05, 2008
SOURCE: Bad water & ice cube taste
We have the same problem; it started when we moved to a house with well water. Now we buy ice and dump it in the ice maker and drink bottled water. All this money for a side by side with water and ice despenser for nothing! We also have front loader washer smell. Is it well water? I miss the city...
Posted on Jun 23, 2008
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
Posted on Dec 08, 2008
  • 531 Answers
SOURCE: blinking red light on ice maker
check icemaker
Posted on Apr 07, 2009
SOURCE: spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
Posted on May 06, 2009
KBFS20ECWH - On delivery, large coil of white tubing behind the two crispers. What is this?
it is most likely the water line. If you are not hooking it up to water, you can remove it.
May 18, 2015 | KitchenAid KBFS20ECWH Architect II...
I have a kitchenaid ksc25inwh00 . is ther a built in filter? if so ,how do i replace or clean it?
bad model number,look in the fridge section up in the top right corner or down in the kickplate to find the filter,if not there follow the water line from behind the fridge to the end of the line,some filters are installed in the water line,check and send model number this number doesn't show up.
May 14, 2011 | KitchenAid Refrigerators
KitchenAid side by side refrigerator doesn't make ice, very slow trickle cold water in door. Removed automatic ice maker and removed ice in discharge tube and reinstalled same. Problem not resolved. ...
check for a kink in the plastic water delivery line. If line is kinked do not bother to streighten it out. Replace it. Once the line is weakened it could break and cause flooding. When reinstalling the line and moving fridge back into place ensure that the line is not bent or kinked.
May 10, 2011 | Kitchen Ranges
Where do I find the instructions for the hook up for the water line for the ice machine??? Thanks
down load the instructions from whirlpool / all hooks are general . / you need a ice maker water kit / home depot will have this with instructions also most appliance parts carry the whirlpoo kit . ( its very simple . . ) . mm
Jul 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water hook up
give me the model number and I will tell you where it is and give you a web page for where it is located and when you do get this info pleas rate for the help for free question. I will be waiting for the model number. the ice maker is fed threw the same line as the water. and is connected at the back.
Sep 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
I know this sounds really stupid, but I think that my water line is frozen for the ice maker in my kitchenaid superba fridge. Everyone is suggesting using a blowdryer to defrost the line. My stupid...
The water line would run up the back of the fridge.
I don't know that the line could freeze, but I'm no pro. I just wouldn't think that would be possible.
Has the fridge been moved lately? Maybe the water line got pinched? Try checking where the water line runs, maybe it got pinched somewhere else (under counters/sink, etc).
Jul 31, 2009 | KitchenAid Superba Architect KSCS25INSS...
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
KitchenAid KBRP20ERSS Stainless Steel Logo
71 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
