Question about Dyna-Glo D-E37 Wall Mounted Panel Heater
I had purchased this unit RMO-80LPT heater several years back, I never installed unitl this week. the sales en at the time told me it was gas/propane. Now seeing the -80LPT on the side is it propane only? I have it installed properly in an enclosed porch. However it's tied inot the huse natural gas line with 1/2" blk pipe. The pilot light right away but the heater will not light. I do not see any areas to switch fuels and regualtor looks vary simple see no adjust ments on it by pulling front lower cover. I need to be of understanding is this unit propane only? and if socan the regualtor be changed to a gas unit.
    Scholar:
  • 146 Answers
The orifices for a propane heater are much smaller so you will not be able to get the natural gas to flow properly with the current orifices.
The both the natural gas and propane valve are 1/2 psi so the valve can be used but the regulator for propane is typically 8-11 inches on the wc table and the natural gas is typically 3 lbs on the wc.
You may be able to drill out the orifices in the burner and in the pilot ods and get the unit to work.
Posted on Oct 14, 2010
Where and how do I register my reliance hot water heater
Save receipt for warranty purpose.
Without receipt, the warranty is based on date of manufacture which can be several months, or 1-2-3 years before actual installation.
With reliance, first two digits of serial number are date of manufacture. Second two digits are week of the year.
Registration at following link using serial number located on label on side of tank:
http://www.reliancewaterheaters.com/resources/product-registration
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 26, 2014 | Reliance Water Heaters
I have an HP Photosmart 8250 that I purchased several years ago and never used or took out of the box ( left a company after it was sold, and that employer let me buy a different existing higher end...
i was told to junk it. i have the same problem. it is nice of hp to let you spend the money on the ink. after all that money and go figure the same problem. thank you hp.
Oct 22, 2012 | HP Photosmart 8250 Ink Jet Printer Q3470A...
What is draining my car battery?
sounds like perhaps it is time to purchase a newer car and let that one find a new home . our daughter had a problem like this and after much expense was told to unhook every thing electrical she could . ended up being the radio/stereo in the trunk.
Mar 01, 2017 | 1999 Pontiac Bonneville
My Haywood H250FDP heater fires up for a few seconds and goes out. After several tries I get a Low gas pressure/No gas error code. I had my propane suppier come out and check. He tried to adjust the...
the flame sensor/thermo couple can be bad and or needs cleaning --carbon build up [one day old -one year old- 20 yrs old defective or damaged parts can happen any time]
Jul 04, 2011 | Hayward H-series Electronic Gas Pool...
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
These have poor quality safety parts that fail in about 1 season or less, the failure rate for these little cheaper units is high, go Honeywell next time!
Jan 11, 2011 | Patton PUH9000-U Heater
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Hi, My 60 inch Sony projection model # KDF-E60A20. Purchased March of '06. About 1 year and a half ago she started giving me problems. Every 30 secs or so tv would go "black" and no sound for about 30 secs...
This could be caused by dust on the bulb. Dust can cause the unit to over heat and will shutdown for a few seconds to a minute and then come back on when it has cooled down. This time can vary depending on the location of the unit and the temputure in the house. The dust becomes hot and so the Thermal unit shutsdown for a short while and then comes back on.
Clean the bulb by removing the cage and using compressed air and a micro fiber towel and install back intot he unit. Make sure you follow the Sony Maunal. Also make sure not to touch the bulb as the oils from your skin will cause it to burn out quickly.
Jun 20, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Dec 22, 2007 | Samsung RS2534 Side by Side Refrigerator
Dyna-Glo D-E37 Wall Mounted Panel Heater Logo
219 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
