Question about IBM Wheelwriter 6 Typewriter
I put in a new wheel and new ribbon with correction tape; was working fine but all of a sudden, it won't print correctly. It prints on the very top edge of the ribbon and the letters do not print correctly.
  • IBM Master
  • 3,594 Answers
On the older WW's there is a large black plastic gear on the R. side of the printer they do get tooth for tooth. try wiggling it to free it up, with the power off it should move easily.
DickyO
Posted on Oct 18, 2010
Printing on the top half of the characters
Is your platen snapped down all the way? Can you look at the ribbon and see where the letters are striking the ribbon?
Apr 01, 2014 | IBM Office Equipment & Supplies
Install lift off tape cartridge
Remove the ribbon by pushing the blue lever to the right and front of the ribbon. The correction tape cartridge is attached to the bottom
of the Printing ribbon. Depress the center of Printing ribbon to release the correction ribbon. Snap on a new one.
Nov 04, 2013 | IBM Personal Wheelwriter 2
How to install correctronic ribbon
Open top cover, small correction tape orange or yellow lift off is kind of tricky, left side goes on small spool holder feeding off the top and going around front of print wheel. by the way relaase the printwheel so it pivots back toward you, eaiser to see, correct tape goes in front of wheel and pivots very similar to left side. Correction tape has good side and bad side good side a matte finish should face away from you, this is the correction. Regular riboon just lifts up reom the front and snaps back in place. two little plastic tabs on back of ribbon case fits in two little holes in carrier. Hop this helps real hard to describe.just works...
Sep 29, 2013 | Brother Gx-8250 Correctronic Electronic...
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
When I type it is printing different letters than I am typing.
On most models there is a pitch switch 10.12.15.PS
you need to match the switch to what print wheel is in the typewriter. most common wheels are 10 or 12
move the switch to that area.
if that is not the problem take out the ribbon, corr. tape & print wheel. tuen on the typ. let it home, put the print wheel & ribbon ( Not the corr. tape) turn on let it home tray typing. if works O.K. put in the corr. tape .
Then you are good to go.
Jan 29, 2009 | Office Equipment & Supplies
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Smith Corona PWP90 corrector cartridge problem
sounds like the corr tape doesn't have the proper tension on it. turn wheel on corr tape cartridge, or if there isn't a wheel, some don't, there is a little lever to the left and under the left side where the cart. fits down. push this until the arm on the right side moves to the left
Jan 02, 2009 | Smith Corona Wordsmith 200 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Typewriter suddenly will not print!
It's been awhile since I've worked on these.
What is the typing mechanism in here? I believe Brother was using a wheel.
Jun 19, 2008 | Brother EM-530 Typewriter
Printing issues
There are a few things that can cause this. Try code Q if this helps you may have a gummy print soleniod, if it dosen't the cap on the solinoid plunger may be cracked or the platen might not be fully seated ib the frames.
Hope this is helpful
DickyO
Dec 28, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 6 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
