Question about DBX EQALIZER, DUAL 31 BAND, INPUT AND OUTPUT TRANSFORMERS => Model 3231LT Home Equalizer
Zip zap i need to know how to fix a transformer bumblebee zip zap toy there was some hair on the back wheels i took it off to get the hair off the little blue gear looking peiace will not go back on
The little blue gear - not the one attached to the rear axle - is easy to fall off when the axle is removed, but easy to put on - if you know the trick. Once the rear axle is off, gently pry the chassis from the body using a flat screwdriver and prying between the tab on the bottom and the body. The body will snap from the chassis. Now, on the drive ('driver', for the USA) side, you'll see a small black nub (actually the drive gear attached to the motor) next to a small silver stub. The blue gear that fell off goes on that silver stub. Here's the trick...angle the blue gear so that it engages the black stub/gear 1st, then push the blue gear onto to the silver stub. If you try to get the blue gear attached without angling it, the black stub/gear blocks the reassembly. Carefully turn the car over, attach the axle with the wheels/tires, then reassemble the chassis/body. Good to go!
Posted on Dec 27, 2008
Where can i get instruction
Here are the instructions. There are 3 separate pages to view on the left side of the web page.
Transformers 2 Revenge of the Fallen Bumblebee Voice Mixer Helmet...
Nov 19, 2014 | Hasbro TRANSFORMERS 2® Bumblebee Helmet
I need the manual for the Bumblebee deluxe transformer. I can't find mine, thank you Maria
There are a couple of Bumblebee deluxe transformers. Here are instructions for two I found. I hope one of them is yours :)
http://www.hasbro.com/common/documents/6d10613f5056900b10551f83244448ff/2B220CC25056900B1057797A4EC0DDC0.pdf
http://www.hasbro.com/common/documents/dad2d6781c4311ddbd0b0800200c9a66/9C354D6B5056900B108E66DFEBB6BBE9.pdf
May 15, 2011 | Toys
I need clear step by step instructions on how to transform the transfomer ultimate bumblebee from robot mode to car mode
Preparing For Transformation
  • Begin with the action figure fully transformed into Bumblebee. Face the figure toward you and bring his arms down to his sides and push his legs together. The figure should end up with all parts parallel to one another. At this point push the legs up toward Bumblebee's chest. The legs will slide upward so do not bend them.
  • Creating the Hood
  • With Bumblebee's legs secured, use your finger to lift under his chest plate, bringing what will be the hood of the car upward while the windows of the car will shift 90 degrees downward. Now bring the arms of the action figure straight up.
  • Final Transformation
  • The final step to transforming Bumblebee back into a car is to take the arms that are pointing up and bring them forward while also moving them toward the center of the figure. Notice the shoulders of Bumblebee have a rotating joint. This is what is used to guide the arms into place. Do not force them or the arms will break off, instead keep them moving until they firm into place, leaving no parts of the figure moving freely. Flip Bumblebee over and he will be in his car form.
  • Jan 20, 2011 | Hasbro Transformers Ultimate
    Instructions to transform bumblebee
    there are a few different bumblebee models but I believe this one may be the one http://www.hasbro.com/common/instruct/83... copy of transforming directions Good Luck
    Nov 20, 2010 | Toys
    We don't have the manual for the Hasbro bumblebee
    http://www.hasbro.com/customer-service/browse/_/Ntt-bumblebee%20transformers?Ntk=All&Ntx=mode+matchallpartial
    Jun 04, 2009 | Hasbro Transformers Ultimate
    448 people viewed this question
    Top DBX Audio Players & Recorders Experts
    Chickenwatt
    Level 1 Expert
    Vito Vacirca Jr.
    Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
