Question about LG WD-1280FHD Front Load Washer
LG WD(M)- 16220FD Error LE
I have got this error on my front loader washer machine and i have the user manual so i know it is motor over load. I am a multi skilled enginner so i stripped the unit and cleaned and checked all. The error is intermittent. The drum trys to turn but it is as if there is something stopping the rotation (there is not) The drum turns freely. Also when /iff it gets to do a full spin it seams slowwer and make a deep winning noise when slowwing down. I have a suspision that either there is a motor driver on the main pcb down or there is a problem with the dircet drive motor. Can anyone send me the circuit diagram or help with this. Ta Chris
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The problem you are having is with the Hall sensor. To be 100% sure, here is the test proceedure, it is located on the stator. Replace this and your problems will go away. If you are not already using HE detergent, start using it, as well cut back on your fabric softener.
Sgt 48
Posted on Jun 04, 2008
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Jan 14, 2013 | LG WD-3243RHD Front Load Washer / Dryer
Washing machine Lg 7kg WD 1256 problem LE sign direct drive the cylindre move difficult and stop
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jul 10, 2011 | LG WM2487H Front Load Washer
LG front loader washer error LE how to fix
probably a defective motor hall sensor. will require dissassembly of motor via rear panel of machine. you will need a #17 socket and breaker bar to remove rotor nut. also, you will then need a #10 socket and driver to remove motor stator. sensor will be underneath attached to stator.
Jun 26, 2010 | LG WM1812C Front Load Washer
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
5 year old LG WD-1219BD has error code LE, ''overload in motor''
LE is a very bad error unfortunately. It means that your motor communication is being lost. Generally on these LG washers it means that you need to replace the motor sensor. You will have to take the back panel off so that you can access the motor, remove the pulley and take the motor off, there is a little plastic sensor that clips onto the edge of the motor. The sensor is not sold separately from the motor so you will have to replace the motor unfortunately.
Part would cost you around $120 plus labor.
This is a common error on LG. Better to repair and use it or fix it yourself.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | LG WD-1295FB Front Load Washer
the problem lies on the speed sensors on the main direct drive motor (the connection with the thin cables) but the problem is that it is not a seperately replaceable item and comes complete with the main stator coil unit this is very pricey at over £120+vat trade price then an engineer will charge his fitting fee on top of this. maybe worthwile looking at buying a new machine
Jul 19, 2008 | LG WD-16110FD Front Load Washer
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WD-1280FHD Front Load Washer Logo
370 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
