Question about Dell F3534 Touchpad
My touchpad reponds to nthe touch only intermittently..sometimes I have to "searc" for a spot to move cursor, other times I have to press hard
  • jjtrautle393 Oct 13, 2010
    worked first try!
  • Dell Master
  • 3,530 Answers
What you may want to do is adjust the sensitivity. Go to Start, Control Panel, Mouse and you should have settings there that you can change.
If the above does not help, unistall and reinstall drivers via Device Manager. If you un-install it, it comes back every times MS scans for new hardware.
If everything else fails, I believe you have a defective touchpad. This is a known issue for Dell touchpads. You need to replace the Palm Rest assembly (which includes the touchpad). However before doing this, check if your computer is still under warranty. If it is, take in it for a service.
Here is the link for the step by step process on how to replace the Palm Rest assembly.
All the best!
Posted on Oct 13, 2010
  • Jose Cada
    Jose Cada Oct 13, 2010
    Glad to have helped. Thank you for using Fixya!
Need to swipe touchpad numerous times for it to move
I would suggest you to check the touchpad app in control panel. I guess your have synaptic drivers installed see if you can adjust few settings to suit your touch sensitivity.
Aug 24, 2012 | ASUS Computers & Internet
Tip
Typing on a laptop, cursor jumps to different places, you suddenly type in a...
This is a very common problem to people who purchase a new laptop, or change from a desktop computer to a laptop. When typing, the cursor suddenly moves all over the place (but usually up) and you find yourself typing elsewhere in the document.
The secret is... the touchpad.
When typing on a standard keyboard, people usually rest their palms on the front portion of the keyboard, or on a special palmrest. Typing on a laptop is a slightly different experience - you have to keep the hands more apart, to avoid placing them on the touchpad.
But even if the hands are apart, you have to move them slightly while typing to comfortably reach the upper rows of keys. Depending on typing habits, the movements will be larger or smaller, but there is always some movement.
Now consider this. If you look at your hand from the side, you will notice, that the base of your thumb protrudes down the lowest. When moving the hands while typing, you very gently touch/stroke the touchpad with the base of your thumb - even if you don't feel it :)
Unfortunately the touchpad feels it, and acts as if you deliberately moved the cursor and placed it somewhere above the spot in the document you were actually typing in.
There are two remedies.
First, and one that has to be excercised anyway, is to try and keep the palms well above the surface of the touchpad. It takes some practice to change one's typing habits, but eventually you'll do it. It's just a matter of finding a palm placement that will be equally comfortable, but will also lower the possibility of involuntarily touching the touchpad.
Second is to go to your system's controls, find settings for the pointing device, and search for options regarding touchpad sensitivity.
There are multiple flavors of these settings, so it's not possible to give one standard recipe, but if you have an original touchpad driver installed (as oposed to using a standard mouse driver, which is enough for the system to recognize the touchpad), there should be a special settings screen for it, and among other options, a sensitivity setting.
Sometimes there's also an option (checkbox) designed specifically to fix this issue - usually it's called something like "eliminate problems with light touch" or sth to that effect.
Please try it, I guarantee that in 99% of the "sudden cursor movement" cases this is the actual cause :)
Good luck, and please don't forget to come back and rate the tip if helped :)
on Jul 24, 2010 | Computers & Internet
How to Fix Windows 7 cursor jumps backward while typing Outlook messages.
Well, technically it is not moving it backwards, it is moving the cursor to wherever the 'pointer' is.
You need to STOP resting your palm(s) on the Touchpad.
When you touch it, it will move the cursor to wherever the 'pointer' is....which is likely where you started typing.
You can also turn-off the touch-pad if you will be doing lots of typing. This is done by pressing [Fn] and [F3].
Aug 23, 2012 | Dell Fire Red 15.6" Inspiron N5110 Laptop...
Orange light comes on occassionally on mouse pad and cursor freezes, how do i stop this
Tap the orange light quickly two times to enable the touchpad. Touch the same spot twice to disable the touchpad. To see the instructions from HP type "mouse" into the Search Programs and Files. Click on "Change mouse settings" and click Device Settings. Click on "Settings" and click "Touch pad disable zone". I was delighted to have found this as I had been restarting the computer manually to enable the touchpad. Shame on HP. The instructions for this simple problem are difficult to locate for the average user. They can do better.
Dec 08, 2010 | HP Compaq Presario F730US Notebook
The curser keeps jumping from the current spot back to somewhere where I've already typed
Are you relatively new to this laptop?
I'm asking, because I suspect that you suffer from the same problem many laptop users have, namely too sensitive touchpad. I myself had this problem with one or two laptops...
When you keep your hands low and parallel to the keyboard, it sometimes happens that when moving the hand slightly to reach keys in the upper keyboard regions, the base of your thumb just barely touches the touchpad, resulting in moving the cursor :) The base of a thumb is protruding lower than the thumb itself, and is not very sensitive to touch, so one does not feel the base barely sliding up the touchpad.
There are two solutions.
First is to go to touchpad settings, and make it less sensitive to light touch. Better yet, some touchpad drivers have a function to prevent from accidental dragging objects by light touch, which needs to be enabled.
If the driver lacks such adjustments, the only remedy is to try and position the hands a bit higher than you currently do. It may be hard at first, but it's relatively easy to form a habit of it :)
Good luck :)
Jul 10, 2010 | Dell Inspiron 9300 PC Notebook
While I type, often the cursor moves to the poit where the mouse icon is locatde, as if the touchpad has been pressed.
yeah you have touch sensitivity set to high in the touch pad and your wrist is hitting the touch pad. go your touch pad settings in the control panel and turn it down til when your wrist brushes it, it doesn't move the mouse.
Mar 23, 2010 | Dell F3534 Touchpad
WYPEHAT i T hERE IS A GOOD EXAMPLE. WHAT I TYPE
well it is no use if u reinstall the OS if the problem is with your touch pad so if it is within the warranty period try to get replaced or buy a new one
Jan 05, 2010 | Dell F3534 Touchpad
The touchpad will move the cursor but will not repond to double touching it to select an item.
in your control panel, look for mouse, and then there is a little jack in the box icon there to test the sensitivity of the double tap for the touchpad. try adjusting it there
Good Luck!
Dec 27, 2009 | HP Pavilion dv6000z Notebook
Cursor tend to go spastic when I touch the keyboard on my Dell
hi,
I had this problem and it was solved by turning off the touchpad in the bios,
Pressing the f10 ? or f2 ? during startup will get you into the bios
are you sure the mouse is ok ?
Regards
GeWiz.
Dec 10, 2009 | Dell Latitude D800 Notebook
Laptop Touchpad - cursor random dragging problem
On my acer all I have to do is press function F7, Function is the button with 'Fn' on it. I am not sure if that works for HP, but its worth a try. Also, is there a switch near the touchpad? Sometimes there is one that switches the touch pad on and off. You can also try other Fn(function) F1 or Fn F2 etc. and see if one of the other "f" buttons work.  I hope this helps, let me know how you made out. Good Luck!
Jan 16, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Computers & Internet Logo
543 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
