Question about Electrolux 23 in. ESI6104 Built-in Dishwasher
Our dishwasher does not drain completely and leaves a bit of water covering the bottom at the end of the cycle. We tried running the disposal during the cycle to see if that clears a drain, but it did not resolve the problem Is ths a plumbing or appliance issue
    Problem Solver:
  • 17 Answers
This might help, i had same problem, right where the dishwasher hose connects to the disposal, it was partially blocked with grease, loosen the hoseclamp, pull off, and scrape it out.
Posted on Oct 24, 2010
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
MY GE DISHWASHER IS CONNECTED AND RUNNING, UNIT HA...
hi just try this Is the door open or unlatched?
Make sure the door is completely closed and latched.
Was the selected cycle interrupted before completing?
The Clean light will come on when the cycle is complete. Wait until the Clean light comes on before trying to manually drain dishwasher. Press Cancel/Drain to try and drain the standing water.
Is the water level just covering the pump module?
This is normal. A small amount of water will be seen in the bottom of the sump area at the base of the pump. This is to ensure that the pump seal does not dry out.
Is the dishwasher drain hose connected to a garbage disposal?
For many dishwashers, the drain hose is connected to the disposal and the knockout plug must be removed from the disposer inlet.
Is the drain system blocked?
Run the disposer to clear the drain system.
Do you have an air gap at your sink?
Check to see if the air gap is blocked by foreign material. To clean the drain air gap, follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover, unscrew the plastic cap, and then check for any soil buildup. Clean if necessary.
Is there a loop in the drain hose less than 20" (50.8 cm) above the floor?
Make sure the drain hose is looped up so that it touches the underside of the counter before connecting to the sink drain or disposer.
Is there a kink in the drain hose?
Replace a kinked drain hose.
Did you reuse an existing drain hose?
Make sure to use the new drain hose that came with the dishwasher.
Is the sink drain clogged?
If the sink is not draining well, a plumber may need to be contacted. Most dishwashers connect to the sink drain. If the sink drain is clogged, the dishwasher can't pump out water.
Is the drain hose too long?
If the supplied drain hose was replaced with a longer one it must be shorter than 12' (3.7m).
May 17, 2010 | Dishwashers
Does not drain water out at end of cycle, I have tried cleaning out all the screens,have opened the impeller cover and checked that the impeller is clean and free. When I put together, it runs for 2 or 3...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Bosch 24 in. SHX33A02 / SHX33A06...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
DISHWASHER DON'T DRAIN
Check the drain.
This could be a clogged drain line especially if the drain connects to a disposal. Some drains are semi-transparrent and a good light will show the clog. I use a long piece of tubing (snake) to dislodge the clog.
Also, if this does connect to a disposal make sure the dishwasher drain hose is elavated when it leaves the disposal so disposal debris will not get in the dishwasher drain line. You may have to tie the drain line to keep it elavated.
Jan 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Electrolux 23 in. ESI6104 Built-in Dishwasher Logo
227 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
