Question about Kohler - Toilet - One-piece - Gabrielle - K14257-WS-47
The toilet fills slowly and not to the fill line
  • 132 Answers
Adjust your water level float if you have one or turn your inlet for water up higher.
Posted on Oct 13, 2010
How do I fix a running toilet
replace the guts first,with universal ones,5 bucks at walmart,what happens is calcium builds up inside them and slowly closes the fill hole,just like your shower head,its easy to install the new "guts", Fluidmaster Universal Fill Valve 400ARP25 The Home Depot
install toilet fill unit Bing Videos
Jul 20, 2015 | Home
Water supply to toilet fills up tank too slowly
Valve fully open on inlet going into toilet if it is then fill valve needs to be replaced check water line for any abstructions that might interfere with water going into tank.
Apr 02, 2014 | Kohler Home
I have a Jacuzzi Perfecta commode. It has worked fine until all of a sudden, the tank began filling very slowly. It now takes from 5 to 7 minutes for the tank to fill. I've replaced the flush valve,...
keep going...i mean disconnect the supply line from the fill valve, hold the line into a bowl/bucket and slowly turn the water on. is there pressure? sorry for delayed response if you text me back i will try to answer expeditiously:)
Jul 26, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
When I flush thenwater fills to the fill line and slowly keeps on dripping over the top of the flush valve tube.
I would ckeck to see where water fill line is inside toilet tank and then adjust flush valve to try to get it to shut off at this point. Not knowing whether your toilet still has original flush valve it is hard to tell you how to fix it. If it has float mounted on rod to flush valve there is usually a set screw on the top of the flush valve in the center. Turn this screw clockwise to make valve shut off sooner. Try to set it so that water shuts off when it is at fill mark. If float is mounted on brass float rod you can support rod closest to flush valve with left hand and carefully bend rod down a little with your right. This will cause flush valve to shut off sooner. If the seat is worn to badly in flush valve you will need to replace it.
Nov 18, 2010 | American Standard 2004.014.178 Champion 4...
My toilet fills very slowly and only half way
There are multiple things to diagnose on a problem of this nature. I will give you a starting point, and you can work from there. If you need further steps, let me know. It may be something as simple as debris caught in the diaphragm of your fill-valve. This is not uncommon. The top portion of your fill will pop off, but you must shut water to the tank off first, before removing the cover. Underneath the cover, you will see a black rubber diaphragm. Remove this diaphargm, and slowly crack open the shut off valve just enough to start water flowing. If you notice any debris come out, your problem is solved. Reassemble the fill-valve, turn water back on. If this is not the problem, Your fill valve may just be bad. They are relatively inexpensive. However, before buying a new fill valve (assuming that step one did not solve this problem for you) Turn the shut off valve back off. and remove the supply line going to the toilet. Get a bucket and aim the supply line into the bucket. If this is not a flexible supply line, this step will not work. However, if it is flexible, point it into the bucket and turn the shut off valve on. If you have adequate pressure at this point, it is definitely your fill valve inside the tank. If there is not adequate pressure, it starts getting a little more complicated to diagnose. However, I can still walk you through those steps as well, but start where I recommended, as this is most commonly the problem.
Nov 20, 2009 | Kohler Cimarron Comfort Height elongated...
I BELIEVE IAM HAVING SOME TYPE OF VACUME ISSUE WITH TOILET
The water in the tank is not filling to the water line, thereby not providing enough water to flush properly. Adjust the float so that the tank fills to the water line
Apr 27, 2009 | American Standard Colony 2388.012.222...
Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Apr 06, 2009 | Kohler K-3422 - Wellworth Elongated...
PLUMBSHOP HUSHFLO #516 Toilet anti-siphon/valve replacement Kit- The tank continues to fill very, very slowly after shutting off. Can the valve be cleaned? I have sediment problems with grit in the...
Usually, there is a diaphram located at the needle valve that can be removed and cleaned and or replaced. If you know you have grit in the water, then you are right, that will cause problems with the fill valve not fully closing.
Mar 07, 2009 | Home
Toilet fills up slowly
buy a universal fill valve and replace it
Jan 03, 2009 | Home
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Kohler - Toilet - One-piece - Gabrielle - K14257-WS-47 Logo
85 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
