Question about Sport & Outdoor - Others
Blowing black smoke when i rev it up and the feums are very strong, maybe a little blue and white smoke hard to tell
  • 132 Answers
Too rich poss.air fuel mix needs to be adjusted.
Posted on Oct 13, 2010
I have a 5L-E toyota hilux that runs fine at idle yhen when you rev it to about 2000 rpm it starts to blow alot of white smoke. I have cut injectors out while the smoke is blowing with no noticable...
i believe the engine is running too lean as if it was running too rich it would blow black smoke If it was blue smoke it is oil related eg valve stem seals,valve guides and or piston rings all of these things will create blue smoke if one of the above is worn out
Mar 26, 2014 | Toyota Hilux Cars & Trucks
Ssangyong musso. 2005 2.9 diesel. turbo. hard to
turbo seal is blown allowing oil into air intake charge-white/blue smoke=oil- black smoke=rich fuel mix-replace turbo-cheers Denny
Nov 01, 2013 | Cars & Trucks
My d16z6 blowing liquid and white smoke out tailpipe
look to see if you have antifreeze mixed with your oil do it by checking the dip stick if it looks greyish then your head gasket is probablly bad
Mar 02, 2013 | Honda Cars & Trucks
My bike wont stop smoking and wont rev properly i carnt put the power down on the bike it feels like it is missing on full revs my bike is a kx 85 motocross 2007 model
If it's blue smoke, maybe an oil ring is broken. White smoke and water in the combustion chamber, black smoke carburation problems.
Feb 07, 2011 | kawasaki KLX 110 Motorcycles
Cutting out in first unless have revs up starting to blow smoke lost power in all gears little bit of backfiring
White smoke means blown head gasket. Black smoke means to rich of fuel. Backfire could be timing is out sounds like timing chain or belt is going.
Feb 01, 2011 | Ford Laser Cars & Trucks
My smoke comes through my pipe
Well, it's the type of smoke that really matters. Does it smoke black? Blue? White? White for the first ~2 miles/5 minutes of warm up is not a bad thing, just blowing out condensation. White smoke that never stops is a sign your head is warped/head gasket is busted. Blue smoke is a sign that you're burning oil bad. Black smoke indicates an overly rich fuel condition.
Dec 18, 2010 | 1993 Acura Legend
My car is blowing smoke and shuddering ef falcon
What color is the smoke ? is it bluish or is it white ?
The blue colored smoke would smell more like burning oil, which would indicate a broken piston ring, ect. the white smoke if it smells of coolant(anti-freeze) would lean toward a head gasket problem.
Feb 06, 2010 | Ford Futura Cars & Trucks
White smoke blowing out the exhaust and oil consumtion on r.cyl.
Its most likely your rings. They get worn and start letting oil into the combustion chamber. They aren't extremely hard to replace.
May 13, 2009 | 2001 Suzuki VL 1500 Intruder LC
My scooter is blowing alot of white smoke and bogging down.
replace the spark plug 2cycle engines are hard on plugs also sounds like it needs a carb cleaning black smoke means carb is fooding
Apr 01, 2009 | 2005 TN'G Verona 150
Black smoke
Change your air filter and clean the blow by tube that crosses the heads and connects to the back side of the air filter. If the tube or the air filter is clogged, then the oil that the blow by removes is going back into the cylinders, causing the black smoke. Also keep in mind that a Harley will blow a little black smoke upon starting as it ages, it's normal.
Jul 26, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
