Question about Nokia 3110 Cellular Phone
My calculator has been removed from the phone3110c.how i would get it.it happens always when i switched off my phone after opening the phone the phone hangs and the calculator application removes by itself and the phone does not work properely. please give me a solution.......
    Guru:
  • 317 Answers
Frnd this happen when mobiles software get corrupted try to formate the mobile
visit bleow link to see tutorial
http://www.fixya.com/support/r5875102-format_nokia_mobile_phones_3110c_2700c
Posted on Oct 13, 2010
HOW I FIX THE MESSAGE I GET WHEN I HIT NAVIGATE - ROUTE CALCULATION FAILED
Doy you get that message always, or only when you are inside a building or close to very tall buildings?
Make sure your device has a clear view to open sky, so it can find enough satellites, to calculate where it is. And if this happens, give the device enough time to find out. It could take up to one or 2 minutes before it is ready.
Jun 03, 2014 | Navigon 2100 Max Portable GPS System
How to fix decimal on BD-6355MT calculator? It used to work before but it stoped.
Same just happened to me. Remove the 2 little screws and then carefully prize open the calculator. Remove battery and leave out for some time. It will then reset to default and your calculator will work as before.
Sep 15, 2011 | Staples SPL120 Basic Calculator
I have a scientific calculator and up till now, the answers were given as just a number ex: 8/4 = 2 Now, the answers are always given as a decimal: 8/4 = 2.00 How do I go back to regular answers?
What happens if the result is not an integer? Anyway, you must have changed the display mode to FIX (and two decimals.) Just change the number format to one of the NORMAL (Norm1 or Norm2).
Press [SHIFT][MODE] to open (SetUp) and select Norm.
Aug 25, 2011 | Casio FX-115ES Scientific Calculator
The screen is black, and won't change or show anything else, but can still be turned on and off.
I had the same problems and non of the standard fixes worked for me. I try clearing the memory, re-loading the OS, removing the batteries overnight, etc. Removing the batteries helped but only for a few seconds and then it went back to a black screen. I removed the grounding shield (open the calculator and remove two small screws and remove the shield). The calculator now works fine without the shield. It appears that the shield was shorting some of the capacitors. You can always put it back if it does not work!
Feb 01, 2011 | Texas Instruments TI-83 Plus Calculator
My calculator is gone.. how to recover it please tell... i have tried by restoring factory settings but nothing happened.. please help!!!
You cannot recover the calculator without flashing /update firmware the phone So, you have to do something just follow the instruction..
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
7210cfile And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose7210c rm436.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......thanks for votes
Sep 28, 2010 | Nokia 7210
What i have to do so that can i my security code on my phone3110c
www.nokialockcode.com      open this site ntr ur imie.
Aug 06, 2009 | Nokia 3110 Cellular Phone
Nokia 5610 camera standby problem
my phone is nokia 6288 and has a problem with the camera. it has stopped working and when I play videos, it gives a black background and restarts
Sep 16, 2008 | Nokia 6288 Cellular Phone
Sir
The default security code for Nokia is 12345
IMEI: 357354019146083
Master code: 7320657337
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Jul 02, 2008 | Sony Ericsson W200i Cellular Phone
Message
this is happening because there is some problem in the firmware so ...
this firmware problem might have occured due to some virus attack or due to the sudden removal of the battery when the phone is in switched on condition or due to the sudden switch off of the phone when the battery charge was low ....
give restore factory settings once ...
this will solves all your firmware problems ...
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution
Jun 28, 2008 | Nokia 3230 Cellular Phone
My 6233
hi, i have a nokia 6233, when I open a calculator or when I try to open email application (which is default in nokia) the phone switches off. I updated the firm ware, Then too I have the same problem:(... Is there any solution for this ?
May 28, 2008 | Nokia 6233 Cellular Phone
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
