Question about HP Photosmart Premium C309A All-In-One Printer
I am getting a clear carriage jam message on my HP Photosmart Series C309. There is not paper jam but I still followed the steps from HP Solution Center and to no prevail. When the carriage moves to the right is where the problem seems to be. It sounds like it's off line or something. Please help!
SOURCE: error - carriage jam message
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Posted on Mar 10, 2008
jonniewalker
  • 1031 Answers
SOURCE: carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Posted on Jan 05, 2009
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Posted on Apr 20, 2009
SOURCE: carriage jam on HP photosmart 3310 all in one
Here is the actual solution from the HP website for a carriage jam...click on the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&tmp_track_link=ot_faqs/top_issues/en_us/c00786043/loc:12&lc=en&dlc=en&cc=us&product=439491
Posted on May 04, 2009
SOURCE: carriage jam error statement on hp photosmart c6180 printer
Carriage jam open door , clear carriage jam and press ok. How?
Posted on Dec 31, 2009
Though i have no paper jam, it keeps on prompting Clear paper jam then touch ok. Also notice the carriage not moving from right to left ,its making a weird noise.seem paper feeder gear stuck but clear
Hi vidya kowlessur,
I would be happy to help you with your Officejet 7500A printer. I understand you are seeing a message prompting you to clear a paper jam, and the carriage is likely jammed. Please use the following 2 documents to troubleshoot the issue;
HP Officejet 7500A E910a and E910c Wide Format All in One Printers Out of...
Carriage Jam or 0X610000F6 Message Displays for HP Officejet 7500A E910a...
I hope this helps, but if the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 09, 2015 | HP Officejet 7500A Wide Format...
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
Improper shutdown message and carriage does not move at all.
Hi Tom Speer
I would be happy to assist you with your Photosmart 5520 printer. I understand you are seeing an improper shut down message and the carriage will not move. Although you may not be seeing a carriage jam message, you might find the following document helpful:
Carriage Jam Message Displays for HP Photosmart 5520 All in One and HP...
If the issue persists, I suggest calling us. What you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
I hope this helps.
Jun 17, 2015 | HP Photosmart 5520 e-All-in-One -...
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Clear carriage jam
The following video shows clearing paper jam in
HP Photosmart C7280....but it applies also for HP Photosmart C6100 All-In-One? Series :
http://www.youtube.com/watch?v=Qs-Lyw5xXLg
Mar 11, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Carriage Jam
>follow the steps on this link to clear carriage jam on your printer
>please inform me if this has resolved your issue.thanks
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00243856&cc=us&lc=en&dlc=en&product=421139
Sep 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
Carriage jam on hp photosmart printer
Solution
Jan 05, 2009 | HP Office Equipment & Supplies
HP Photosmart Premium C309A  All-In-One Printer Logo
252 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
