Question about Microsoft Xbox 360 Console
I have a xbox 360 ... had problems with the disc drive not loading, i replaced this ..... now i have sound but no picture ??? but if i conect to atv using my hdi lead it works.... but the normal lead dose not ??? any easy fixis ??? pn/ ido not have use to the hd tv so only can use trough red white yellowlead ?? please help
  • 4,102 Answers
Hi the problem you are having is going to be one of 2 things, the first thing to try would be another lead just in case your has got damaged or a short somewhere see if you have a friend who can bring their lead round just for you to try, if it still dont work then the chances are you could be having problems with the gpu chip but dont think this until you have tried another lead.
if another lead dont work then it could either be the port thats damaged or it could mean a fault on the circuit board due to over heating.
check if you have any warranty left on it as this will be covered by warranty
let me know what happens ok
Posted on Oct 13, 2010
Hi there my xbox 360 will play dvds/cds but will not play games it just says play dvd when a game disc is inserted in the console can you please help me thanks mr shane arnell
Sounds like the Xbox 360's disk drive is starting to fail. Knocking on the top of the Xbox (when its on its side) while loading a game can sometimes get it to work, but its better to have your Xbox repaired or replace.
Apr 19, 2011 | Microsoft Xbox 360 Console
When turning on my xbox 360, it will not load any games automatically. it says open tray, i open and close tray several times for it to finally load the game so I can play. Also at times when gam does...
This is a problem occurring in all the xbox 360 consoles....... this is mainly because of the poor quality of the disc,.....as a result it leads to the damage of ur xbox lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
all the best.......
Dec 07, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: I've had problem with my Xbox 360 reading my discs...
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email xbox360repair@palegathon.com for a pricing for repair.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
May 18, 2010 | Microsoft Xbox 360 Console
My xbox cannot read discs
Your laser is starting to go weak in the dvd drive. Try using a can of air and blow some into the drive. This will remove any specs of dirt or dust from the laser.
If you do this and you still run into the same problem then the laser for sure is definitely going weak on you it will need to be replaced. You can find replacement lasers on Ebay for the Xbox 360.
Aug 22, 2009 | Microsoft Xbox 360 Console
My xbox loads games but then it freezes on games that run on a disc
Hi, im not sure but are you playing the games of the xbox 360 Hard Drive?
If orignal discs seem to freeze in the drive then this could be a problem with the disc drive. You may want to get it replaced or if under warrenty get it replaced...
if the problem happens with games that run from your hard drive as well this could be a hardware problem.
Jun 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 open tray error
sounds like the whole assembly is off track or ruined. here is a great site that you can use to order the complete assembly and replace this malfunctioning one. Click here.
Mar 11, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
XBOX 360 DVD DRIVE CONTINOUSLY OPENS AND WILL NOT LOAD ANYTHING! WAS PLAYING FABLE 2 AND MADE CHEWING SOUND AND DISC CAME OUT AND AFTER THAT WILL NOT REMAIN SHUT
The laser or the dvd drive needs to be replaced. We can do this for you if your interested email us
xbox360fixer@verizon.net
Jan 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 says to play disc put it in an xbox 360 console
The box isn't loading the decoder softwarer for the Disc. The Xbox discs are encoded HD DVD-ROM discs, and the box needs to recognize them so it can load the decoder software. It probably says "play dvd" on the xbox dashboard right?
Apr 22, 2008 | Microsoft Xbox 360 Console
Non playable discs
Hi i had the same problem on my 360,
so i got a new laser off of ebay,
and that didn't fix it so then i read some fourms,
and found that my drive motor that spins the disc was broken,
so i replaced that and now the xbox is working like new again :)
Jan 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
