Question about Toshiba TDP-T91A DLP Projector
I REPLACED THE BULB ON MY TOSHIBA TDP-T91A BUT THE LIGHT IS STILL RED. WHAT SUGGESTIONS DO YOU RECOMMEND.
  • 320 Answers
SOURCE: Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Mar 06, 2009
SOURCE: toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Posted on Nov 12, 2009
  • 23 Answers
SOURCE: Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Posted on Jan 21, 2010
  • 15 Answers
SOURCE: toshiba tdp-s3 projector
It sounds like the high voltage portion of the power supply (ballast). Turn to the solder side of the P/S board and orient it so the silkscreen is legible. Check for burnt resistor R573, 2Kohm. It's center of board, 3/4" from bottom edge. If that's OK, check 3.3kohm resistors R621, 622, 625, 628, 629, and 630. They're in the top right corner. They tend to crack. Good luck.
Posted on Feb 20, 2010
news775
  • 699 Answers
SOURCE: JUST PUT NEW BULB IN
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 18, 2011
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
Do this projector has a filter that can be changed
1,Clean the filter
2,reset the filter timer: menu-setting-used hours of filter-reset the timer
Feb 10, 2014 | Toshiba TDP-T91A DLP Projector
My TDP- T91A gets hot on one side is ther two fans in this projector or just one? I hear one fan but it seems to get pretty hot on the other side of the projector. I just received this and it is new to me....
Lamp life is affected by a lot of things. Is the projector mobile or is it permanent mount? How many hours a day is the projector on? There is no set time for bulb replacement. When it burns out it's a good idea to have a replacement already to go when needed. If the projector gets too hot, it will shut itself down as a safety precaution.
Jan 19, 2018 | Toshiba TDP-T91A DLP Projector
The DLP Projector Toshiba TDP-S8 has consumed the number of hours alloted for the used . Is the bulb of this unit can be replaced?What is appropriate size of bulb for this unit?
yes it can and here is a link to a site with the correct bulb for you http://www.myprojectorlamps.com/projector/Toshiba/TDP-S8.html please let me know if that was helpful
Mar 14, 2011 | Toshiba Computers & Internet
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
I just replaced my bulb on the toshiba tdp t45u projector and the red lamp light is still on and the projector still wont come on? how do i fix?
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
Apr 11, 2010 | Toshiba TDP-PX10U DLP Projector
Jan 05, 2010 | Toshiba TDP P4 Multimedia Projector
Toshiba tdp-s3 projector
still looking for a schematic, i'm a tech for 44 years myself, but on unfamiliar territory don't travel without the road map. The bulb probably isn't getting high voltage, but i'm unfamiliar with the circuitry. y'all showed having the schematic. but i couldn't operate your forum page
Dec 30, 2008 | Toshiba TDP-T3 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Bulb light projects red
Hi there
I guarantee you 100% that this not a bulb problem but rather a Mainboard failure.
This can unfortunately only be resolved by having it repaired or replaced.
And it is expensive incase you were wondering.
Mar 26, 2008 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP-T91A DLP Projector Logo
59 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
