Question about Cisco 7912G IP Phone
This morning ,i see "Ethernet disconnected " on the screen of my ipphone. What should i do?
Why does my Roku box not detect an ethernet connection after 6 years hard-wired?
Its better to access the Roku secret screen for you to check if the Wired MAC address is still showing, because if it is all zeroes and not alpha numeric, it means its a defective ethernet port. To do this start from the home page. Then using the Roku remote press the home button 5 times, fast forward 3 times, rewind 2 times. On the upper left side look for Ethernet or Wired MAC, it should show alpha numeric.
Aug 26, 2014 | Televison & Video
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:
Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices.
Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.
Aug 14, 2012 | Edimax EW7416APn (EW7416APN) Pre80211n...
Hi my name is Ana this morning the RTL818X seems to be disconnected, it works ok everyday but today a red cross is on it how can I change it?
It seems that the network (ether net )cable is disconnected.
Please check whether network cable or Wireless network is disconnected.
Mostly, the Ethernet cable would have been disconnected in other end of it.
Please plug it properly. It should resolve it.
Jan 27, 2011 | Computers & Internet
Good morning. i require ethernet lan driver for HP Presario V6000 6425TU laptop
Here's a link you can use.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3463460&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Apr 27, 2010 | HP Computers & Internet
Cannot connect to internet when Symantec is running and:
Disable the Symentec fire wall and try,Still if you face the same isssue reset the router and re-connect the cable and check..
May 26, 2009 | Linksys Wireless-G Broadband Router
Media disconnected
If you are using one box (or modem/router) only, when your computer says media disconnected, it means that your computer does not detect your modem.
You can try unplugging and replugging the ethernet at the back of your computer or laptop. make sure that the light on the ethernet port is lit up (especially for desktops, not sure about laptops though).
You can also do the same process with the ethernet cable from your modem/router. if your modem/router has other ethernet ports in it, try to connect it to other ports as well. If your computer still says media disconnected, try purchasing or borrowing a new ethernet cable.
Also make sure that your ethernet adapter is working properly and that media disconnected follows after ethernet adapter local area connection and not wireless connection.
Hope this helps!
May 04, 2009 | D-Link AirPlus DI-524 Wireless Router
Ipphone will not turn on
If you can hook it up to your computer set it into recovery mode. Update firmware then remove from recoverymode then it should work. I think
Sep 15, 2008 | Cell Phones
Converting to SIP
connect a crosscable between your cisco 7940 and the laptop
start a dhcpserver and a tftpserver on your laptop
The files i mentioned (SIP license) have to be purchased at Cisco.
start the IPPhone, thats all
Aug 26, 2008 | Cisco 7940G IP Phone
3crgpoe10075 status led blinking with no stop
hi ,,, i got yor problem. as ya said its not allowing ya to log nto it with security enabled. Ya can try to log into it with the ethernet cable as their wil be an ethernet LAN port onthe access point. I f ya know the default or the present ip of AP then ya can assign a static ip of the same range to yor computer like eg. ap is 192.168 .1.1 then your comp can have 192.168.1.10 and ya can log into it thru the ethernet cable and disable the security. i hope ya know how to assign a staic ip add to yor compuetr. or check the screen shots on brivers.com n select the "network connections" screen shots to assign a static ip address to yor' comp. feel free to chat with me on samrat101 thru yahoo or msn messenger or drop a mail on samrat101@yahoo.com for ny wless n ipphone issues -- take care ,, samrat
Nov 23, 2006 | 3Com OfficeConnect 802.11g/b Wireless...
Cisco 7912G IP Phone Logo
150 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
