Question about Sentry Fireproof Safe
We haven't opened our safe in a long time and have forgotten all information on how to dial our numbers. One time around then back to the other numbers? Just what is the proper rotation? PLEASE help need papers very soon. Thank you Mary
  • 3 more comments
  • Mary Rogers Oct 13, 2010
    The numbers on the front or the safe are OSO407 and BD619152 My husband is trying to find where he put the paperwork that vcame with the safe. Mary
    Hi, thanks for the instruction book. However I very carefull did the dial combination three different times and I still can not open it. Is there some way to change the combo? We are having a problem finding the manual, hopefully my husband ddn't put it in the safe. When it says to turn the dial to the left, does that mean if the 0 is at the top does the 0 go to the left or does it go to the right?
    Mary
  • Mary Rogers Oct 14, 2010
    Hi, we still were not able to open the safe, so my husband took it to a lock shop and they pried off the door. Now we will get another only this time a key pad one. Thank you for all your help.
    Mary
    Yes, leethedeuce was very helpful and knowledgeable about the information he gave me.
    Mary
    Silverdragon, that is exactly what we did do, thanks for the information. You guys have been very helpful.
    Thanks Mary
  • 4,472 Answers
First off can you give me the exact model of the safe, once I have that information I can assist you further.
Thank you,
Lee
Posted on Oct 13, 2010
  • 1 more comment
  • Lee A.
    Lee A. Oct 13, 2010
    You can view the manual for your safe at this link:
    http://www.sentrysafe.com/pdfs/OwnersMan...
    The second page of the manual explains how to open it.
    Thank you and enjoy,
    Lee
  • Lee A.
    Lee A. Oct 13, 2010
    The link I gave you is the manual. The 0 should go to the left if your turning it left. If you continue to have an issue you may need to contact sentry directly:
    https://www.sentrysafe.com/ContactUs/Cal...
    Thank you,
    lee
  • Lee A.
    Lee A. Oct 14, 2010
    Did you have the locksmith try and use the code first? Be careful with the keypad safe. They can be just as hard to get open when the battery dies. Please reconsider and accept/rate my solution accordingly.
    Thank you,
    Lee
  • 12,061 Answers
Usually, iy used to be, the lock turns to the RIGHT First, then Back LEFT. BUT... they did used to muddle mechanisms up, I mean it is a SAFE.. it is meant to be very hard to get open without the right "Key" or "Code", to make sure no-one knew what to expect, so they made it the reverse to add another layer of protection.
Your best bet, though, is to call a registered locksmith, he will open your box, one way or another
Posted on Oct 14, 2010
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
Ihave brinks firesafe model#5059, serial#042589 . Ihave the keys of it,but forget combination number pl. help me how to set it.
1-800-223-8566 m-f pst 8-4
Call the number above, give them your model #, the serial number (located on the right side of the safe next to the model number), and your key code. They will provide you with the combination to your safe. your combination number will be provided to you immediately.
Also, you can try
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Take care.
Jun 21, 2010 | Computers & Internet
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking Sentry Fireproof Safe open.
Nov 16, 2009 | Sentry Fireproof Safe
Brinks fire resistant safe model 5059 instruction manual
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
Apr 30, 2009 | Computers & Internet
Brinks safe
As I understand that safe has four numbers to the combo. 1) turn the dial to the right passing the first number 4 times stopping at that number the next time around. 2) Turn the dial to the left passing the second number 2 times and stopping on that number the next time around. 3)turn the dial to the right passing the third number 1 time and stop on that number the next time around. 4) Turn the dial to the left stopping on the last number. 5) Insert the key into the cylindrical lock and turn it to the right.
Sep 03, 2008 | Check Point Network Adapter
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
To bad you dismantled. Here is the turning sequence:
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
Jul 16, 2008 | Computers & Internet
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
Pull the handle down; cracking sentry safe open.
May 06, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
672 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
