Question about Panasonic Lumix DMC-TZ3 Digital Camera
Formatting external memory card
Hi there. your info was fantastic...except i can't find an option for formatting the card while in the camera...i can't find my manual...and i leave for italy in the morning. help!
thanks!
susan
  • 78 Answers
You can also format the card in a cardreader in the computer...
Posted on Jun 14, 2009
Just buy a new card in italy SDHC not SD it being 2 or 4 GB
Posted on Jun 06, 2008
Formatting memory card option not available with the camera USB
Try with a memory card adapter and connected at pc as external device, just format then.
Aug 05, 2012 | Canon PowerShot SX100 IS Digital Camera
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
I have a brand new canon powershot sd1400 and it says memory card error. Please help! One answer I saw was: Go to the menu screen, scroll over to the tools option, scroll down to format and format the...
You may try to install memory card into an external reader for a pc and try to format that way. Place card in camera and connect camera to computer via usb cable and try to format that way. I had a canon that the only way to read the card was when it was in the camera, if I tried to put memory card in an external reader it would not recognize the format. Canon does some wierd things with their stuff. Good luck and if this was helpful please vote. Thanks.
Feb 13, 2011 | Canon PowerShot SD1400 IS Digital ELPH...
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
How to format my memory card ........window format is not allowin
Hi just try these steps 1. go to the gallery, then press the option button and then click on the format memory card option. your memory card will be formatted
May 30, 2010 | Nokia Cell Phones
Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
I forgot my password for the external memory card
Format it using a Digital Camera, if does'nt solve the problem then buy a new one because once an external memory card got locked by a password, it can no longer be recovered.
Oct 30, 2009 | Nokia 5200 Cellular Phone
How to format my 4gb memory card for my motorola phone using my kodak easyshare camera
You don't mention what model of Motorola phone you have, but most (if not all) that accept a memory card have a format option. I would use the phone format function rather than the camera.
Aug 02, 2009 | SanDisk 4GB microSDHC Memory Card
Does not honour the memory card
change the internal memory card mode keep external
Jun 18, 2009 | Kodak EasyShare M1033 Digital Camera
Lg lp500 cookie mobile wont store automaticaly into memory card
Hi, with the Cookie you have to set your camera and video settings to external memory seperately, even though you have already made external memory your primary storage....its weird! I don't have the phone with me right now to check but open up the camera by clicking the button and while the icons are on the screen tap the one that looks like a cog, this takes you to the settings page for the camera, under one of the tabs here you will see two memory type options. Tap the 'external memory' option and away you go! You need to do the same with the video settings.
Jan 24, 2009 | Cell Phones
Panasonic Lumix DMC-TZ3 Digital Camera Logo
59 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
