Question about Dishwashers
Hi In the middle of a wash cycle, my dishwasher tripped the circuit breaker on the wall. I diagnosed this by unpluggin dishwasher, plugging in a different appliance and switching circuit breaker back on. new appliance worked OK. When dishwasher had cooled, I tried it again on same circuit (which I knew was working properly). The lights came on for about three seconds, and then the circuit breaker cut back in again, so I knew it was the dishwasher that was causing the problem. Is there anything I can do - I'm not a bad handyman - or is it a job for the technician? Thanks for your reply. Ray
  • ray_cooke Oct 13, 2010
    Dear Heatman
    Thanks for your advice. Sort of confirms what I thought but I needed some confirmation like yours to put me right. As the machine is already 7 years old, I might just bin it and buy another. Like you said, if I call a guy out to it, he might just want to change parts on it and that ain't worth it.
    Best regards
    Ray
  • ray_cooke Oct 18, 2010
    Thanks. This sounds really plausible. The same sort of thing happened to me once with an electric chain saw. I fixed it myself by chopping off a bit of burnt wire at the place where it goes into the housing of the saw.
    Best regards
    Ray
    President:
  • 1,891 Answers
Ck the connections where the cord hooks to the wiring harness. look for hot or shorted wiring . also ck the contro panel for the same . generaly if you have a power draw like you are saying then you can see the problem . mm
Posted on Oct 14, 2010
  • Dishwashers Master
  • 43,501 Answers
Hi Ray,
Because the circuit will noly stay on for a few seconds the tracing down of the problem could be difficult. Can you tell if the breaker trips if it sounds like power was applied to the motor or did it just buzz and tripp???
If it sounded like the motor tried to start then I would guess it is a motor problem...if it just buzzed and tripped then a wire maybe rubbed through...
Often times the best way to track down the problem is with an OHM meter...tracing the circuits till you find the one that is causing the problem...this can be tedious and time consuming...
If you are comfortable with that type of troubleshooting...go for it...if not then calla tech. in to troubleshoot it, but make sure that he has done that before and is not just a parts changer...that can get very expensive...
heatman101
Posted on Oct 13, 2010
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
My dishwasher was in the middle of a cycle and it just quit. The buttons dont light up. It doesn't turn on at all. What could be wrong with it?
Sonya, have you checked the circuit breaker in your home's circuit breaker panel to see it has been tripped? Also, is the dishwasher door tightly shut? If the breaker is tripped, reset it to see if the dishwasher trips it again. If it does, either breaker is faulty or the dishwasher has a short circuit in the electrical circuitry. You'll need an authorized service person for that.
Mar 21, 2011 | Heating & Cooling
I have a bosch dishwasher model # I believe is SHX4AP05UC it keeps tripping my braker in the middle of washing wont complete a cycle any suggestions?
Adam, in order to help you, you must provide me with more info. What size breaker is tripping. What does the maufactor's manual reads about what size circuit it must be plugged into. If your house is a little old you probably have a 10 amp breaker that is tripping. If so than the manufaturer states theat it is recomamded to place it onto a 20 amp breaker. Only switch out the 10 map breaker to a 20 amp breaker if your the wire from the breaker is a 12 gauge wire.
Do not put a 20 amp breaker onto a 14 guage wire because it will most likely melt the insulation due to heat whichwill expose the bare copper wire which could lead to burning your house down.
Dec 02, 2009 | Bosch Dishwashers
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Will not turn on after stopping in middle of a cycle
Check the following to address this issue--
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 02, 2009 | Kenmore Dishwashers
Dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Jan 08, 2009 | Bosch Dishwashers
Seem to have an earth fault with a prima lpr 450 dishwasher runs for about 15 min then trips our electric.It did a few times from new (about 3 years old now) then stopped doing it, now does it nearly every...
Hello gcsounds,
If I understand your problem correctly, it appears that you have a ground fault ( or earth fault) that is causing your breaker to trip. I am assuming ( but don't know for sure ) that your dishwasher is hard wired into a junction box and that junction box is fed power from your circuit breaker panel. I am also assuming that the circuit breaker is either a Ground Fault Interupt ( GFI ) or standard type and that breaker is what you are saying is tripping with every wash cycle. There are some details that need to be filled in for me by you in order for me to fully understand your wiring scheme and suggest ways to resolve your problem. First off, can you provide details on how your dishwasher is wired ( as I suggested above or other) and secondly, what voltage are you running it at? If you are in the US then in all probability you are running your dishwasher at 120VAC @ 60 hz but if you aren't then please elaborate. Once I have that information, I may be able to assist diagnosing and resolving your problem.
Regards,
Rick
Nov 22, 2008 | Dishwashers
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
Owen Barnes
