Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
Error code 007 but no paper is jammed.
2 Suggested Answers
Logjam
  • 159 Answers
SOURCE: Panafax UF-885
paper jam error codes rely on input from sensors in the paper path. On this machine there is 1 sensor that is triggered by a mechanical actuator on the cartridge. Actually, the cartridge is generic, except for the position of this actuator. It is part of the guard that prevents damage to the drum, when it is removed from the machine. The positon of the actuator is different in the case of 4 different manufacturers who use this engine. Now, the effect of this actuator is to tell the machine that a cartridge is actually present in the machine. Now, some cartridge re manufacturers have removed this actuator entirely and technicians will jam the sensor in the machine with gum or a piece of paper to allow the use of this generic cartidge. Unfortunately, the paper path becomes obstructed, not with paper, but by the media that the technician has used to de activate the sensor. Look for this and replace the media with something more robust that will not become dislodged.
Posted on May 27, 2008
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
System error 007
Hello and thank you for using Fixya
The 007 error code means your copier is experiencing a non-detection of the upper roller/fixing film, and it's not spinning correctly. You will need to check out your film's condition and also check the green handle in this area for a possible paper jam. Replace the fixing film and the error will go away.
michael34
Mar 09, 2011 | Canon iR 2016i Black and White Copier
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
Feb 14, 2011 | Canon iR 2022 Printer
What does TCR error code 007 mean - wheere can I find a list of error code expalnations. Online manual no help
This error code 007 means that there is a line fault could be the fax you are sending to, Plug a phone into your skt & test to see if line is crackling.
Dec 16, 2010 | Muratec F320 Plain Paper LED Fax
My canon IR 2018 copier is giving me system error 007
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
Hi there...we have an error saying paperjam - code=007. I have checked for paperjams and there doesnt visually appear to be any. What can you suggest?
When you removed paper from the machine, did it rip at all? If it did, a small scrap could have been left behind, causing the jam code. Depending on where the machine is located and who uses it, there might also be a foreign object lodged in it (like a staple or paper clip). If you think there is nothing in there causing the jam, try turning the machine off and turning it back on, and see if it still shows the jam.
May 27, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Whats the 09 007 42:4609 error code mean on my
The machine thinks the yellow ink chute isn't working. The inkloader may be jammed or defective.
If you can't un-jam it, you will need to replace the inkloader.
-Whit :)
Jun 30, 2009 | Xerox Phaser 8560MFP Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Panafax UF-885
May 14, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
78 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
