Question about Roper Washing Machines
I have a Roper washer modelRAS6233RQO the lid switch burned up and burned up the connector on the end of the wire, I ordered the switch but can't find the connector anywhere without buying the whole wiring harness, Can you help me ?
  • 4,340 Answers
Cut the wires back WELL FAR enough to be past all overheating damage, and splice in new wires of the same gauge. I suggest using heat shrink tubing, two layers, as insulation. these should be soldiered connections.
Posted on Oct 13, 2010
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
Roper spin cycle
The "tab" you are referring to is connected to the lid switch. Symptoms of a defective lid switch may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 3949247.
HINT: If you have determined the lid switch to be defective and would like to use the washer in the interim while awaiting parts, you can make yourself a by-pass plug by following these steps:
1. UNPLUG the washer.
2. Remove the lid switch by following the instructions in the link I provided.
3. With the lid switch in hand, cut the white plug off the end, leaving about two inches of wire.
4. Cut the center wire (ground wire - usually green or green/yellow in color) flush.
5. Take the remaining two wires (usually black or gray in color) and splice them together using a wire lug.
You have now made your yourself a by-pass plug that you can re-use if necessary. Take the by-pass plug and plug it in to the timer connector and the lid switch is now by-passed.
CAUTION: You will need to turn the timer off in order to stop the washer now. Only use this as a TEMPORARY repair until you can replace the lid switch.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Apr 28, 2010 | Roper RAS8445KQ Top Load Washer
CAN'T SPIN OUT
do you mean the little prong that sticks into the lid switch to make the lid switch funtion so that it can spin you need to order the piece that he broke off on the lid or If he is mechanically inclined have him open the top find the lid switch connection and use a jumper wire from positon 1 to positon 3 on the lid switch wire connection this makes the unit run normally whether or not the lid is open or closed if he is mechanically inclined two phillips scews in back of unit to open the head
How do I open the top of the washer to get to the lid switch to change? Washer is a Roper RAS8244LQO
You take 2 screws out holding the timer panel on (one on each end of the plastic), flip it up (it's on hinges), unplug the lid switch where it goes through the case, then remove the 2 clips on each side holding the back to the case. The entire case then comes off.
Jan 28, 2010 | Roper RAS8244LQ Washer
I need to access the lid switch on my Roper by Whirlpool washer.The washer will not move on to the next cycle. I had been able to "fiddle" with the switch and get to to go on, but not now. It is as if...
Good day,
There are three different styles of switches.
As well, there are three locations where the mounting screws that hold the top console on.
Exposed, one on the bottom, each corner. One on the bottom,each corner, but hidden by plastic end caps, that need to be unclipped first. Finally, on the rear, as shown in the clip.
Here is an excellent tutorial on your problem.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Thank you for using FixYa
Jan 23, 2010 | Roper Washing Machines
HOW DO YOU GET TO THE LID SWITCH ON A ROPER RAS6233KQO TOP LOAD WASHER? HOW DO YOU GET THE TOP OF THE WASHER OFF?
On the back of each END piece , there is a phillips head screw . Remove both screws and the console will slide foreward and tilt back . Remove the 2 clamps by prying out from the front of the clamps . Remove the lid switch connector and the whole cabinet will tilt foreward . Remove the 2 screws holding the switch and the plug for the switch wiring can be removed . Reassemble in reverse . BE SURE TO UNPLUG MACHINE FIRST .
Jul 24, 2009 | Washing Machines
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
Roper Washer model RAX4232KQ0 won't fill with water
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 02, 2009 | Washing Machines
I have a Roper Washer Topload (model RAX4232KQ0) and recently replaced the lid switch because it was broke. That fixed my problem but created another one though. I put the machine back together and now it...
good day to you sir from fixya,those colors go to the water level switch.the switch may have the color marks on it,or you can look at the wiring diagramthanks for using fixya.God bless your house,tom
Washer stops half way through rinse
check the lid switch on the washer loosen the two screws on the control panel end caps pull the control panel slightly forward and tilt on its hinges then you will see a connector under the panel it has three wires one is gray one is green i think the other is tan unplug the connector and put a jumper wire from gray to tan to by pass the switch lower the control pane and start the washer to see if it continues if it does replace the lid switch
May 24, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
106 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
