Question about Apple iPod touch
Ipod Jack stuck
My earphone jack broke off and got stuck in my ipod and i cant get it out.
  • Anonymous Jul 03, 2008
    my earphone got stuck in the headphone jack of my ipod touch.
  • ADRiiBaBy Apr 09, 2009
    i pluged my headphones in one day, then when i pulled it out the tip end of it got stuck in the jack, any advise/help.?
    President:
  • 4,402 Answers
Take a needle and pry it up and out.
Posted on Jun 11, 2008
Can I use headphones on a Kindle?
Some Kindles have an earphone jack and some don't You can use earphones only if your Kindle has the earphone jack. It is the mini-jack like used in iPods and iPhones and many headphones (as opposed to ear buds) use a larger size jack.
Adapters are available. Try Radio Shack for adapters and lead cables. Keep in mind that most earphones require more power to operate than earbuds do and the Kindle may not be able to sufficiently power headphones to get any decent volume.
Apr 08, 2015 | Audio Players & Recorders
Headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Jun 11, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
Jan 13, 2011 | Apple iPod nano
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
My itouch earphone jack creates static in earphones.
sounds like the typical ipod and ipod touch common situation. It seems to be the dreaded headphone jack on the bottom or top of the device has gone belly up. You can either take it to your local apple store or look online and search your problem and see if anyone else has the same issues you have and see what can be done.You can send it to ipodsquad.com to get repairs or check your local apple store.
Oct 12, 2009 | Apple iPod touch
Headphone plug broke off and is lodged in the jack.
broken earphones are usually not repairable due to its miniature construction. i am sorry to say it's more likely you need to buy a new one. if you are really a person that loves music so much and pays attention to sound details, i suggest you buying a good quality earphones like Sennheiser. Though this has a trade off when it comes to price.
I found this on YouTube:
http://www.youtube.com/watch?v=pAAZ0vLcfGA
Oct 06, 2009 | Apple iPod nano
Apple ipod mini 6GB earphone jack not working
The earphone jack is connected to the logic board, open up your ipod mini and see about replacing the logic board with one from ebay. Easy to do, just be careful.
May 05, 2009 | BoxWave Corporation Apple iPod mini (6GB)...
Earphone jack not holding the plug in place
unfortunately this is a hardware problem the plug-in has been damaged or was previously damaged so u will have to go to the store and get it replaced. :\
Mar 09, 2009 | Apple iPod touch
Ipod doing wierd thingg
First off - Is there any warranty warranty left? Otherwise what most likely happened is the headphone jack connector broke a terminal. If it is a model with a screen, the headphone jack is a separate piece off the motherboard. It's a cheap part off of ebay, just find someone with nimble hands to reconnect the ribbon cable inside.
Apr 24, 2008 | Apple iPod MA446LL/A MP3 Player
Unable to listen to music
This happened to my ipod and it turned out to be some fluff stuck down the headphone jack, I took it out and it worked fine!
Oct 01, 2007 | Audio Players & Recorders
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
